How do I find color for interior code?
1yesfan
2001 Silverado Z71. Where is the interior color code on the truck listed?
The interior color code should be the the row of letters/numbers at the bottom of the RPO code sticker inside the glove box.
Near the bc/cc number--on the lower part of the rpo sticker.
92D
GMT800 2005 Tahoe Z71
Navy Supporting Member
I would assume the locations for those codes will be the same on his sticker and since that is not his and yours is a more rare color I bet, at least the outside paint, he will have to do some research. Detective work is fun.
Should be the same. Glovebox, lower right hand on the rpo sticker. My exterior blue is somewhat common.
I thought the blue color, like yours, was not as prevalent as the other colors?
Yea, I have only seen my friend's Tahoe at my American Legion post with that color and 1 other advertised on CL. The most prevalent colors out here seems to be black, white and pewter/silver.
BC/CC is base coat/clear coat. U9792 is indigo blue metallic [the base coat]. 92D is the dash code [pewter].
92 is interior color code. I'm not sure about cloth--but for leather interiors pop off the headrest, flip it upside down and pop the clip that's holding the underside together. There'll be a white tag that tells you what the interior color is.
Welcome to the forum from Oregon. Thanks for the code info. Please post pics of the inside and outside of your rig.
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. While you may have posted pertinent info in your first post, you may forget to do it again and the info is needed by us anyway. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
SgtScrounge
I don't have one yet. Sold my Cadi SRX this morning, going to look at an '06 Denali Saturday. Will post my RPO's and other vehicle data once I get it.
Drewphil
