adventurenali92
So here’s one I haven’t heard about before... 2006 Yukon XL Denali, LQ4 6.0. 140k currently in the odometer.
1. so in the end of March the Nali went into the shop, and the did oil pan gasket, oil cooler flex plate gasket, and did the valve cover gaskets topside. Apparently after only a year of new valve cover gaskets, the passenger side valve cover was leaking bad.
2. fast forward to June and it’s still leaking and finally has time to go in. Shop says valley pan gasket... I’m like huh funny I told you guys to check that out the last time and you said it was fine... replaced the intake manifold and valley pan gaskets.
3. Fast forward to a couple weeks ago... it’s still leaking
ok time to drop the trans and do the rear main seal.... fine let’s get it done. They dick around and not start on it right away, keep it overnight. I’m pissed off but whatever just get it done and put back together. Next morning guess what it’s still leaking motor oil!!!! I’m fuming!
So I show up to the shop on Thursday for washes, only I tell them I’m not washing any of their vehicles until my truck is no longer leaking oil. They put it up on the rack, and apparently the oil pan gasket is leaking again... I’m like wait we just did that In the end of March! So they said they’d fix it under warranty. Thankful for that. They’re also servicing my transmission and replacing the oil pressure sensor/sending unit, since they’re already in there. I figure the pressure sensor is a cheap part and may as well do it now.
sorry for the long post here’s my question: they said oil leaking from the camshaft position sensor gasket, anyone heard of that before? I’ve never heard of it. And secondly they said the plate on the rear main seal isn’t right and leaking...
anyone see an oil pan gasket fail and the plate on the rear main seal not hold up so closely together?! I can’t imagine both have gone bad so shortly.... but what do I know? Lol
ok time to drop the trans and do the rear main seal.... fine let’s get it done. They dick around and not start on it right away, keep it overnight. I’m pissed off but whatever just get it done and put back together. Next morning guess what it’s still leaking motor oil!!!! I’m fuming! So I show up to the shop on Thursday for washes, only I tell them I’m not washing any of their vehicles until my truck is no longer leaking oil. They put it up on the rack, and apparently the oil pan gasket is leaking again... I’m like wait we just did that In the end of March! So they said they’d fix it under warranty. Thankful for that. They’re also servicing my transmission and replacing the oil pressure sensor/sending unit, since they’re already in there. I figure the pressure sensor is a cheap part and may as well do it now.
