07 yukon denali motor mounts go bad every year
retiredsparky
Pete,
Your idea for checking the motor mounts does work. I have used it before. However, I do question how being in reverse will check the passenger side. The torque the motor feels doesn't change direction, no matter the gear selection. The motor and tranny input shaft/pump/torque converter is still rotating the same direction when in reverse. The reversing happens in the tranny after the torque converter, so the engine doesn't know/feel any difference in reverse.
avalonandl
Troy, MICH & Naples, FL
Clunking noise/feel when accelerating then coming off throttle or coasting and then accelerating.
That could also be a sliding yoke sticking on the trans output shaft. We had mine up on the lift and the mounts were ok but the yoke sticking caused a similar issue. If you accelerate slowly it doesn't make that clunk...
91RS
GA
Are you using OEM mounts are cheap aftermarket ones? The aftermarket ones are cheaper for a reason. Use the GM ones and that will last much longer.
91RS
GA
Open hood and apply ebrake, start truck and with left foot holding brake pedal and trans in drive press gas pedal, While looking through windshield observe engine. If bad motor will lift up on driver side considerably, do the same in reverse to check passenger side mount.
This doesn't always work for the right mount because generally the right mount will collapse and cause excess vibration to be felt. When accelerating the left mount gets pulled up and the right mount pushed down so unless someone is flooring it in reverse all the time the right mount will generally not break the same way as the left. The best way to test the right mount is to put it in drive and if you feel vibration then put it in neutral and see if it goes away.
HACK BLOCK
NYC
I have this issue in my work car... I wonder if it's the mount
wjburken
Eastern Iowa
Pete,
Yes, and the transmission is bolted to the engine so as the transmission tries to turn the driveshaft in reverse and is resisted by the E-Brake, the torque will twist the motor/transmission assembly the other direction.
PG01
Up here to the right
Pete,
Try it, tell me what your motor does in reverse on brake giving it gas.
91RS
GA
GMT 900 nut
