Installed these today
extremetint
Plug n play just switch out old ones with new logo one.
https://www.gmpartsstore.com/oem-pa...yQ70ibhe0e1WHlix0GWBsRiEN3cKDouxoCA3sQAvD_BwE
Timers
Nice thanks for info. Will probably have to do this.
wu6fiend
So these things are called "Attachment Kit"?
I like the idea, and would like to add these to my 2016 Denali, if indeed this is just a plug and play addition.
Yes plugs right in
nice, I ordered the bowties already, when those show up I am going to put them in the Silverado (same puddle light) and see if I can modify them for the nnbs also, might be able to shave the sides and epoxy some nnbs tabs to it, not sure if there is enough depth though.
Wonder if these would fit k2xx Esky mirrors?
"maybe" look under the mirror, I parked next a k2xx denali today and looked under the mirror and it was same puddle light as my silverado. if yours has the camera under it then it may be different not sure.
Da90
Tulsa, OK
I really like that they are OE. So much that I ordered them for my Sierra and Suburban. [emoji23]
Thanks for sharing!
RST Dana
OH
Hmm. Ok. Mine does have cameras, but I’ll check it out against the factory puddle. Plenty around to compare with.
RST Dana
OH
GM Part numbers are the same for factory lamps for esky and Tahoe.
brice715
