2020 Tahoe..Air Dam
Phil Rosche
I just bought a 2020 Tahoe with 4WD. The front air dam looks really NASCAR, it hangs down really low. I'm sure my offroading is less than 1% of my driving, but I do occasionally drive in the sand, snow, and mud.
I'm worried about how low the air dam is. It says something in the owners manual about taking it off if you anticipate getting it hit offroading.
Is there an aftermarket air dam that doesn't stick down so low?
What have other folks done?
Thank you
wjburken
Eastern Iowa
Thank you
Welcome to the forum from Iowa.
One thing folks have done is trim some off of the bottom of the air dam. On older generations, they have also been able to find one off of a PPV version as they have been a little narrower.
P
Phil Rosche
How much shorter (less wide?) do you think it is than the one that came on the Tahoe?
Da90
Tulsa, OK
I cut mine to where it’s straight across. I got the idea from here.
gat0r
DFW
just drive it & if it gets rock rash, then trim it a bit.
saves the crazy $$ that GM wants for the PPV version for other mods ;)
canadiandux
