How to remove trans filter gasket?
96-2D-Hoe
Instructions say use a screwdriver but I couldn't get behind it without damaging the case.
I've tried a couple small angled picks but getting nowhere. Have a larger one to try.
Any ideas?
wjburken
Eastern Iowa
Any ideas?
Some folks use a 6” section of threaded pipe, 3/4”, with a tee or an elbow on one end as a handle and thread the pipe into the gasket and pull it out.
96-2D-Hoe
96-2D-Hoe
Thanks for the reply. Is that 3/4 OD or ID?
I had to just put the cover on and stop for tonight
Will have to try to find something at the local hardware store in the morning.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I have always used either a long pick that is angled and has a curl on the end that I could work behind the seal and roll around the outer diameter for sections or one piece at a time.
I have seen the pipe one too. Gotta be careful, either way, to not leave gouges in the housing wall.
wjburken
Eastern Iowa
If you go to a hardware store and buy a 3/4” x 6” pipe nipple, that’s what you need.
96-2D-Hoe
96-2D-Hoe
That's what I was hoping would work but I couldn't think what it was called. There's a builders supply within walking distance. Thanks for the help.
96-2D-Hoe
96-2D-Hoe
I have a cheap set of picks and the small ones were a bit too small to get hold of and the large ones were too big. I managed to put a small angled pick in one side and out the other of my little finger. Gonna be sore in the morning.
Thanks for the advice guys.
wjburken
Eastern Iowa
Be careful to go easy. Only need to get a little bite on the gasket. Remember, the thread is tapered so you will expand the gasket if you go to far.
96-2D-Hoe
96-2D-Hoe
For sure.
I was tempted to leave the old one in but there was so much difference in the size of the new one and old one I didn't want to risk it letting by.
96-2D-Hoe
96-2D-Hoe
I went to two different stores and I couldn't find anything that looked like it might work. The nipples did not have enough taper on them to bite onto the seal. I looked like at one thread on it would be compressing it against the body too much.
What's the right tool for this job?
96-2D-Hoe
96-2D-Hoe
This seems to be the only other option. I didn't want to damage the body if I could help it.
96-2D-Hoe
96-2D-Hoe
96-2D-Hoe
96-2D-Hoe
I'd bet that was the original from the factory. There was only one tiny spot where I could put the small pick and it wouldn't slip straight off. Gave it a few hits and it moved enough to where I could get the screwdriver on it and hit it a couple more times. When it slipped back I pulled out out with long nose pliers.
The new one has a nice lip all the way around and will be easy to get behind/out.
Now I want to flush the trans completely. The fluid that drained out overnight was very dark.
Be careful with that flush. Since you are doing the work, is your flush just a replacement of as much fluid as you can get out of it or done at a shop using their equipment? That equipment should use the trans pump to swap the fluid with.
96-2D-Hoe
96-2D-Hoe
The disconnect a line, turn the engine over, replace as you go method I guess.
Unless there's a better way?
Disable the ignition and turn over engine or actually start the engine? I would not think that all fluid would get out of there that way but maybe it would. Some torque converters had a threaded plug that you could rotate to the bottom and drain it from there. I don't think yours does but I could be wrong.
96-2D-Hoe
96-2D-Hoe
Pull the fuel pump relay and turn it over. Won't completely 'flush' it but AFAIK that's about the only option apart from paying for it at a shop. Seen it on youtube and some people have mentioned/done it here.
Yea, I would not want to start the engine but turning over should push a lot of that fluid out. Use Dexron VI to refill. I use AC Delco fluid but you can get other brands.
Buford bubba
