Rear Differential Fluid Change
bigfootchiro
Largo, FL
Gotta love the mfr video. The music is a little much....
"Centrifugal force moves the pawls outwards to engage the latch..."
And then.....BOOM! The pieces of gears are easily swept up with a standard push broom.....
Also love that they say "maintenence free". Lol.
I like these...
I have blown up one G80 and it wasn't the diffs fault. I like them. An engineering feat with very practical performance, at the very least. However, if romping is the plan, forget it. Put a TruTrac in there and tell your buddy with the gravel driveway to watch his paint job.
I grenaded the hell out of mine hahaha
22BCC033-B8F8-4E30-994D-B7179E0A389C.jpeg 8962FCF0-7698-4366-9695-5C7EE6EBCEA0.jpeg B55461C2-7077-4E57-8531-7F45E035629D.jpeg BA2D590B-2344-448F-A2DF-764357491AF1.jpeg
96-2D-Hoe
I was heading that way. Mine had a huge crack in the body, and the bolt was about to fall out when I pulled the cover off and checked it.
I would recommend If you're going to change the oil, just get a gasket, take the cover off so you can clean it out thoroughly and inspect it at the same time.
2006Tahoe2WD
Silicon Valley
Regarding how much. You should be able to find a guideline for the amount - e.g. one quart or more... Somewhere there will be a statement regarding the maximum level for the fill. For example - 1/4" below the fill opening or fill to the bottom of the fill opening.
