GM Accessories upgraded skid plate
Tk59194
Greetings,
I think this part has been covered in a few other threads but thought I would give my initial thoughts and then follow up with installation photos/remarks.
This is the three piece aluminum/steel skid plate offered by GM as an upgrade to the factory plastic piece. It is listed as a front under body shield and can be found here:
https://accessories.chevrolet.com/p...t-under-body-shield-23176881?categoryId=12001
List price is $250.00. I found the part on several different websites and 250.00 was pretty standard across the board +/- a few bucks. I had a $50.00 GM accessories credit and decided to use it towards buying this piece. All in all, while a bit on the pricey side and probably overkill for a vehicle that rarely goes off road, I think it looks nice and is worth the piece of mind that if offers in comparison to the stock plastic piece.
The front plate is comprised of two aluminum pieces. They are 1/8th inch thick. Very stout and appear to be well made.
It comes with a steel rear differential cover as well. I do not have 4WD, so I will not be installing this plate.
The kit does include the hardware.
I had hoped to install this today, but will depend on the weather. I'll post photos as soon as installation is complete.
Tk59194
Tk59194
Moderators, I meant to post this in exterior. Apologies, please delete or move as necessary.
Tk59194
Tk59194
Thoughts after installation:
As stated before, this is a well built piece and definitely an upgrade to the stock plastic cover.
A few installation notes:
It was necessary for me to "ream" out the holes a little bit on both panels. Not a lot, but a little. The holes were off by about a 16th of an inch. I could get the front or the rear holes lined up, but not the front/rear at the same time. Not a big deal, but for a 250.00 piece designed for the truck, I would have expected it to all line up perfectly.
On another note, the rear two mounting locations for the front panel did not have threads tapped in the holes in the frame. I used two of the old bolts that held the plastic cover in place to tap the threads in the frame. required a little bit of muscle, but the bolts are pretty tough and had no problem cutting through the frame hole. YMMV.
As soon as I can get the truck on a lift, I will snap some decent photos of the covers. Overall impression is that this is a decent upgrade from the factory panel. Offers protection and also does a good job boxing up the frame which should, in theory, provide a small handling upgrade although I cannot confirm this with any factual data.
Cheers!
I didn't know this was made, the black one is for the transfer case and looks the same as mine. Replaced my plastic one last year with another plastic shell that seemed more pliable, the other was beat and busted and cracked. Thanks for posting.
Kpwweb
All the holes lined up just fine. Also, the holes are designed to have the threads cut by the bolts.
Tk59194
Tk59194
I didn't know that, but definitely worked like a charm on my application.
Denali Brad
Greetings,
The kit does include the hardware. View attachment 215676
View attachment 215676 View attachment 215677
Any interest in selling the differential skid plate?
Brad
cireallin
Any idea if this is available in all black from GM or 3rd party?
BrownSunshine
Any idea if they sell just the front piece? (GM/Aftermarket)
Our Tahoe is lifted and came with a new differential skid plate but I would like something else for the front section
PG01
Up here to the right
Ebay, look up seller rodlouvers
Ask him to make it with no louvers
Tiki
Are these the stock z71 plates?
This will fit on a 2019 Escalade?
Do you have to remove any of the parts when changing oil?
What is this one?
https://www.gmpartsclub.com/oem-parts/gm-underbody-splash-shield-23475140?c=bT0xJmw9NSZuPVJlY29tbWVuZGVkIFByb2R1Y3RzJms9MQ==
you are asking 2 different questions, if you mean the previous ones shown in this thread then yes they will fit and no you do not have to remove them to change the oil.
the one you have hyperlinked I believe will only fit with the midnight edition valance but I could be wrong
Escalade2007
