Popping noise from exhaust when 1st cranked
MeHoe
Has anyone had random popping from there vehicle? I been noticing this alot more on my 2000 Tahoe Limited. I know I have high mileage. But my ls swap isn't ready yet so I need to make sure this popping noise is not major. No check lights on no leaks.... I'm leaning towards upper intake or the popits in the spider injection maybe???
Check the spark plug gap?
bsamole
I don't know how to check for it but I would suspect a leaking fuel injector that drops in fuel when the exhaust valve is open.
Multnomah Falls
Military
Yes, both these could be suspect and the spider's are known for leaking.
Are you saying the noise happens while cranking the engine before it starts or the noise is after it starts?
MeHoe
MeHoe
I haven't changed my plugs over due. But the spider injection probably is bad too. I got 287 on the clock of my Tahoe
MeHoe
MeHoe
Really dnt want to chat it out but I dnt want to take away frommy LS swap lol
MeHoe
MeHoe
Only when it 1st starts it does it then it goes away
exp500
Do you have a scantool? Look at misfire counts on each cylinder. Check cap for corrosion. carbon tracks.burn thrus. If plugs bad will show on counts. If you cracked the converters, you could be hearing them rattle to the muffler.That will go away if you drive it hard.
Xay2Smoove
