Maintenance pricing as our Tahoe ages - what’s appropriate now versus waiting
DrNick
Hello.
My old account has been lost since we purchased our 2013 Tahoe new back in 2013. The vehicle has been a real maintenance free machine. Has 110k miles approximately. Z71 LT 4WD. Gone through one battery and set of tires.
Our local dealer has always provided the “recommended” actions during our oil changes. Recently I noticed our passenger motor mount was broken (leaking the fluid) and will have it fixed and figured I would tackle some of these items they “recommend” while it’s there. Also believe our brakes/rotors are due too.
So here is the list, please debate the pricing and if any are truly needed. None have been done to date, we purchased vehicle new.
• air intake $139
• throttle body $89 - well i have done this and they didn’t notice how shiny it was :)
• drive line $375
• transmission flush/clean $199
• cooling system flush/clean $149
• power steering $119
So what’s your thoughts? We have not had any issues with coolant, tranny, steering, or engine performance. Besides the rough idle thingy, I’m just wondering if the fluid components of the vehicle need to be addressed. Should Serp belt be replaced? I can do that myself. But the other Technical maintenance like brakes, etc...I will leave to experts to save time and headache. And I know they are upcharging because they said the mounts were 138$ and rockauto has the same at 98$.
cfmistry
Are you planning to keep the Tahoe? If yes, then I think you should do all of the above maintenance. If you feel the dealer is not worth it anymore as the car ages, I think moving to a quality independent shop is entirely reasonable. But if you plan to keep it another 20k+ miles, then you should keep up with all the fluids/filters.
avalonandl
Troy, MICH & Naples, FL
Your descriptions are too generic. Air Intake ? All you need is a new Air filter. Cleaning TB...$ 8 for the cleaner and some rags and old toothbrush.
Driveline ? U Joints or ?
What about brakes?
GMT800 2005 Tahoe Z71
Navy Supporting Member
First: Welcome back to the forum from Oregon. Plus this......
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. While you may have posted pertinent info in your first post, you may forget to do it again and the info is needed by us anyway. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
I agree with Roger, way too generic. I have never heard of driveline maintenance. What the hell is that? No maintenance but replacement if needed. Maybe lube the slip yoke or what ever they make up. What about plugs and wires? Were they done already. One thing for sure, like my dad taught me, "Maintenance pays and breakdowns cost". If you plan on keeping it I would do the aintenance and find a shop to trust because those dealer prices are obnoxious. Plus, you should shorten the times/mileage between maintenance.
Seamus
Palm Beach
I was in the same bought right after my purchase of a 2013 Suburban LTZ that was very well maintained by the dealer since new. But as you approach 100K it is time to tighten things up. I do not believe in addressing items one at a time as it takes away from your enjoyment of use and can be very annoying leading people to buying new cars. We all know this is a very dependable and predictable platform. I even came back to this truck after 4 trucks of the new platform. I knew how much better the LS based trucks were. So with that said your list is a good start. But I will add to it as preventable and good maintenance.
I would do a filter and change of trans fluid not just a flush.
I don't know what driveline means? But make sure differential fluid is changed out.
I did the serp belt, and all tensioner/pulleys
change all 4 O2 sensors
Change MAF sensor
Spark plugs (The good ones Iridium)
wires
flush brake fluid
check all sway bar bushings and mounts ( mine needed replacing and it was a Florida clean truck) Its heavy!
Upon inspection my axle seals were leaking
Brakes/rotors
synthetic oil/Wix filters
Do a good inspection under and around the truck
Big deep detail of entire truck, lube all weatherstrip, lube all hinges and latches
check all your hoses (I replaced the lower hose) I figured that was the one hose I could not fix on the side of the road!
Check for codes
Alignment
Tires? (highly recommend Michelin Defender LTX) Transformed my truck !
I made this a 1 month project and now its ready to go at anytime and go anywhere good for another 100K
Best of luck
DrNick
DrNick
Thanks! And thanks for the input. We just got back from vacation and was struggling getting new account set up here. I will get that info added ASAP If that helps folks.
The vehicle is stock, no mods. Just the normal oil change and air filter when required. Vehicle runs great and have never had issues. Nothing has been removed or replaced on the vehicle except battery, air filter, motor oil/filter, and set of tires.
The “drive line” is the front/rear differential and transfer case is what I can figure. Air intake is throwing me for a loop, maybe cleaning the sensor? I know it isn’t the filter because that is separate ;).
I can do (And have done) the TB myself, and looking at posts/videos I can take care of power steering, front diff, transfer case, and maybe rear diff. I’m more hesitant on the rear because of the torquing and gasket details, maybe let the expert do that.
We are going to have the brake system investigated because there was some squeaking we observed.
Miami-Dade
Moderator Supporting Member
I agree with all this. If you plan on using a independent shop I would make sure they use only AC Delco parts and fluids. Most independents will let you bring your parts-fluids from the auto store or dealer.
I use both a independent and dealer. The dealer has been decent to me so that is why I switch from one to the other. This way I stay on the good side of both of them. For ATF fluid changes I only let the dealer do it.
When I ran shops it was always discouraged for customers to supply parts. Mostly because customers would try to bring in the cheapest crap they could find and then when a problem occurs the blame is pointed at the shop instead of the crappy part. I did find an independent quality shop that is ran by 2 ASE Master Techs that I had done business with before when I was running shops. I told them I would be doing most of my own work but wanted to use them when I needed a shop to do the work. I asked to supply my own parts and guaranteed them the parts would always be AC Delco quality parts or equivalent. They agreed and the results have been top notch. I also agree with @Miami-Dade about the parts and fluids. Use AC Delco quality whenever possible. IMO.
Hello.
• air intake $139
• drive line $375
Some of this should have been done twice already. The radiator is due, manual calls for 5 years or 150K miles. Keep the fluids clean and she'll run 300K+ miles. Definitely do the transmission and transfer case and both differentials. Your hubs are hitting their historical lifespan, change the brake fluid when you have brake work done too.
Love the Z71 Tahoes, got any pics?
DrNick
DrNick
Codes for vehicle and picture! Will work on getting updated in profile.
BA0F614B-4BE3-40CA-9F20-220C6A31EE03.jpeg 42133FD5-1F94-4B8D-BFC9-FBE1A690F32B.jpeg
DrNick
DrNick
I will bypass the dealer and have a local shop lined up for some items above my pay grade.
I am tackling the spark plug/ wire replacement. Front, rear, and transfer case fluid change. Both belts. And power steering fluid.
today I did the plugs and wires, and front diff fluid. For the plugs, once I figured out the scheme of things it went fast. Started with #8, came off easy Thanks to online tips for extensions, but getting the new plug in blindly was a challenge. The wire and heat shield were difficult too on #8. The rest were easy. The factory had plenty of lube on the plugs/ wires. So I have a spare set! The biggest problem was hearing/feeling the plug engage with the metal clip in the wire on the new ones. Front diff fluid was changed. Metallic Slug was on the magnetic plug but no shavings. Oil wasn’t black more dark cloudy olive oil. Replaced with amsoil severe gear 80w-90. It took a little less than 2 qts, had 3 on hand.
over the next few days I will update on the rest. All items (sans amsoil) were ordered on RockAuto, they exceeded expectations!
the scariest part of today was when I was on the driver side changing a plug and my wife came out to ask if I needed anything. I just naturally grabbed the wire and heat shield and put it on, forgetting I hadn’t tightened or torqued down the plug. Luckily I noticed the socket wasn’t where it was supposed to be.
picture of oil and plugs are attached. What’s the thoughts on the look of the plugs? The First plug picture is passenger side in order and second pic is driver side in order. The other two pics are replicated except close up of the spark area.
D89DB2AE-4EE9-4E03-95C8-F6B155D8FB61.jpeg 6181E3D5-CE7E-41B7-87CA-852AA9A4F035.jpeg 0F00390A-F84A-4289-A616-FDD245DE87CA.jpeg C5751F83-306A-430A-99EC-FEA5E6501FC1.jpeg 931B2186-BF09-4AE5-8D7A-206B775ACE84.jpeg
BG1988
Hello.
• air intake $139
• drive line $375
the MAF sensor is most likely to fail around 100k or so
DrNick
DrNick
Update-
Had local shop do a cooling system flush and fluid replace, plus transmission pan drop and fluid change.
Have R1 geomet drilled and slotted with Akebono proact ceramic pads to be installed next week with fluid flush.
replaced serp belt and AC belt. Glad I got the tool for the AC. Hate that you have to cut it to remove. Tension indicator was about 1/2 way but it is piece of mind.
i changed the transfer case and it was nasty black with fine metal filings attached to the magnet. Change went great. The next day I moved to the rear diff. Much tougher, had to kick out the spare tire and the bolts were on hard and a few parts to work around. PB blaster helped a bit. Fluid came out like a brown ale and just minor metallic sludge. All the internal parts looked good. Cleaned up things and replaced a new gasket. They are reusable but I could see the rubber deteriorating. The more I looked the less convinced I was to even keep it for a spare. Replaced with amsoil. Greased up the two zerks up front too.
last point, brake cleaner is so cool! Never used it before. All things (sans rotors) came via rockauto.
Bigkevschopshop
Northside H-Town
Keep the fluids clean, stay pretty close to factory recommended stuff, and it will last. The major issue most get into with failure is in the engine oil, DOD likes and needs clean oil, it fails when not taken care of well through its life span.
brake cleaner is also good to kill wasps and hornets if you ever need to kill em fast.
I am about to do a flush and refil on coolant myself, the MAF sensor keep em clean I had a 03 tahoe with 245 k on it and still ran fine with orig MAF.
o2 sensors I do suggest replacing though, those things get tons of abuse from the heat, but have seen some go 300k without replacement so its a gamble, I always do AC delco on replacement parts or Delphi, Delphi made alot of sensors etc for AC and its the same stuff normally, few bucks saved most of the time also.
Sounds like your making a good step to keep the gal around for many years to come. Glad to see the headway working out good. Keep up the good work
j_jerry79
