mattbta
Frisco, TX
Got it put back together with all these parts. Started right up! Now to drive a bit and make sure I don't lose coolant. Then after a couple oil changes, send out to Blackstone. Idle is still a little rough and hot oil pressure around 35 but I didn't expect improvement since this was just top end stuff. Might do an oil pump at some point, just hoping there isn't bearing wear.
1 706 ADV CYLINDER HEADS 706
1 6504 MOREL LIFTERS
2 MAH-54441 CYLINDER HEAD GASKET
1 RNB-56390 COOLANT BYPASS SEAL
1 LIL-44180 FAN CLUTCH SPANNER WRENC
1 ICB-551696 BOLT KIT LS HEADER
1 FEL-61070 TB GASKET
1 FEL-72401 PICKUP TUBE O-RING
1 MAH-VS50250 VALVE COVER SET
1 ARP-912-0011 CLEANING TAP FOR LS1
1 ARP-912-0001 THREAD CLEANING TAP
1 ARP-134-3610 GM LS2 HEAD BOLT KIT
1 RFL-2008 EXHAUST GASKET
1 ADO-213-363 ENGINE CAMSHAFT POSITION
1 ADO-D8055 ENGINE OIL LEVEL SENSOR
1 ADO-213-4514 ENGINE COOLANT TEMPERATU
1 FEL-OS30693R OIL PAN GASKET SET
4 12595365 VALVE LIFTER GUIDE
1 551733 LIFTER GUIDE BOLTS
1 PT1798 ECT PIGTAIL
1 F107SX DRAIN VALVE
1 551680 OIL PAN BOLT SET
1 DWA142TH TAP HANDLE
1 63880 3/8" TORQUE WRENCH
1 15179498 UPPER RADIATOR HOSE
1 56500 LISLE TERMINAL TOOL
1 CAPRI TWO WAY AIR GUN
2 41-110 DELCO IRIDIUM PLUGS
1 12563918 OIL LEVEL TUBE
1 11610259 COOLANT PLUG HEAD
rgosart
Put new brake pads on all the way around, adjusted my parking brake shoes, and greased the front end. Trying some Wagner Thermoquiet pads this time. I used AC Delco pads last time I did the rears and they made a lot of noise. Hopefully this fixes that problem!
1 FEL-72401 OIL PUMP
1 11610259 COOLANT PLUG HEAD​
That lists an oil pump, pan gasket and pan bolts. Did you have a shop do the work? If so, it looks like they did replace the oil pump. Edit: that Fel-72401 is the o-ring so that must be what got replaced?
mattbta
Frisco, TX
I did the work. I pulled the pan because it had a little bit of sludge on the bottom. So, for good measure (and it was cheap enough) replaced the o-ring and pan gasket even though they were a tad under two years old.
DenaliReyes
Detroit, MI
I broke the plastic cover of the driver side mirror light....and now
$77!!!! FOR THIS POS PLASTIC PIECE!?!?!?!?!
lol
Sorry for yelling but damn.
DenaliReyes
Detroit, MI
Junkyard time
I wish, there aren't many 05o or close to it Yukon denalis or Tahoe's up in Detroits junk yard. These are driven until they are burned.
How bad is it broken? Might be able to fix it.
The cover piece fell off during g a car wash. The light still works it's just missing a cover. I'll post a pic soon
Antdogbmx
lets see
Used the bottle jack and some wood to realign the bumper on passenger side
Took of the center caps and getting ready to paint them
Painted the other mirror black (WILL BE REDOING IT)
Next try to figure out my A/C issues
CJ Rodarme
Kent, WA
Took some time yesterday to give my rig a much needed wash... just to have it rain out of nowhere 2 hours later lol. I also threw the old stock mirrors back on, I still haven't decided if I like them better or not.
I was on the way to the store today and had my ABS light come on out of nowhere. My wheels rubbed through my ABS wire, never thought of that happening because until now all my wheels had negative offset. Until I can get a new wire in, is this okay to drive on? I'll get the new wire ordered today, but can I drive on it like this for the next few days?
dubyagee01
View attachment 250268 View attachment 250267
That looks routed wrong.
DenaliReyes
Detroit, MI
BrightAF!
I have to adjust the beams, need to find a flat wall. And measure out. Have to look up the numbers on here to get it right. Also the fogs are pointing to low I think.
The DRLs would be on but it has to be in gear gear. Not just on Drive with brake on.
Drewphil
