Putting a 2018 Silverado/Sierra Jump Seat into a 2016 Suburban/Tahoe/Yukon?
Hani orfali
This picture
IMG_20200320_124155.jpg IMG_20200320_124207.jpg IMG_20200320_124148.jpg IMG_20200320_124152.jpg IMG_20200320_124210.jpg
Hani orfali
Since this jumping seat not made to install it between the Captain seat. So it's will make noise when you install it ... So you have to bend the matel little so it's stop squeaks... I hope this help all
KCB2015
Ok finally got this job done , the seat i used came out of a 2018 Silverado . Hope this helps anyone else interested in doing this .
Took me about 9 hours of creating as i go .
KCB2015
Thanks everyone for your help this is a great Forum cheers :)
KCB2015
That’s one badass install. Great work man!
Thanks :) it would definitely take less time for some one else to do this using this method . I basically figured stuff out as I went along . This may help those who are thinking about doing it
but really not sure of what is involved . It's pretty solid no movement at all . I'm going to add a additional mounting strap for center rear lower lock down strap for child restraints .
Also thanks for the heads up on those plugs i'll check it out . cheers :)
BlaineBug
Clown World
I saw a Suburban for sale locally that looks like it cam with its very own OEM jump seat. NOT a bench. If I recall, it was a pre-2015.
KCB2015
Thats a great view of front attachment, here is what I used for rear. A $20 amz seat bracket kit with a couple extra screw bracket thinggies I had left over from a aries nerf install kit (pic 2). You can see it all come together in 3rd pic behind red wire. Red wire feeds gang panel in console; it was fished under carpet/panels to driver side 3rd row power outlet - just pull up cupholder and solder it up under there. Used a 3d printer to fab covers for old armrest holes to finish up...
Sent from my SM-G975U using Tapatalk
Could you make me 2 of those armrest covers ? And how much :)
ASG-MikeS
