'95 Inside Door Latch Issue
homesick
The Best Me I Can Be
Navy Air Force
Hey y'all, is there a common problem with the door latch on these trucks? A particular thing or two to check first?
The inner latch on the driver's door, over a week or so, got gradually worse. I had to pull it a little bit further/harder each time to open the door. It won't open the door at all now, but I never heard or felt anything snap or give. I'm hoping it's just an adjustment issue.
What do y'all think?
Thanks,
joe
haks310
Got LEDs?
SoCal
Common issue. Changed mine out bout two years ago but can't recall exactly what the issue was. Definetly wasnt the rod as thats what I first suspected but problem was fixed with a new interior door handle.
dkknaebel
Keeping LKQ in business
St. Petersburg, FL
I have a feeling that I'll be doing this soon. The handle is slow to return to the resting position
homesick
homesick
Navy Air Force
Thanks man.
Anyone else have an idea?
joe
drakon543
sagging door pins can cause trouble sometimes. the rods that go from the latches might not be allowing enough pull on the latch a simple added tweek at one of the bends can help. the plastic tabs that the rods clip into on the latches can wear causing the rod to lose some of its pull distance. so grab the bottom of the door and lift up and down if you see it wiggle could look into the door pins. next look at the plastic clips for the rods for missing or damage or just wear. generally if you have a rod issue one handle will work perfectly and one won't also similar with the clips. if you decide to tweek one of the rods be very careful to not overstress the plastic clips or you could break them.
exp500
Sometimes a good parts store clerk will find you the metal clips for the rods, old school fix. I like to remove the rod before I shorten it by bending(double bend). A trace on a piece of cardboard is enough to show amount needed.Dorman inside handles usually last a long time. Use your engine hoist when doing door pins/bushings/rollers, easier than floor jack.
liquify33
Houston
*Assuming '95 handle is same as '99*
Mine did the same until it quit. Pot metal connection on the handle broke, think i got a replacement on Amazon for $20-ish and a pop rivet from a neighbor with real tools.
homesick
homesick
Navy Air Force
Thank you guys. I'm taking notes.
joe
liquify33
Houston
Did you get it fixed? If it’s same issue as mine was you’ll be opening the door from the outside very soon.
homesick
homesick
Navy Air Force
I started the outside open thing already, before I made it any worse. I have a new inside handle and am waiting on a rivet gun from Amazon.
joe
Koser
Russia
Thanks man.
joe
Hello colleagues!
This is a constant disease of the square Tahoe Suburban 95-99.
Adjusting the rods and the good condition of the fingers of the loops HELP.
But, forever solves the problem only the material of the pens.
And this is casting.
I made pens from nickel silver ...... and forgot about this problem)
P.S. I don’t know how well I translated my text Google Translator from Russian into English.
https://www.tahoeyukonforum.com/threads/eternal-internal-handles-of-obs-95-99.116494/
IMG_0216.jpg 20151216_140902 (1).jpg IMG_2563.jpg zCAAAgLIEeA-960.jpg IMG_5009.JPG
homesick
homesick
Navy Air Force
Hello colleagues!
View attachment 246578 View attachment 246579 View attachment 246580 View attachment 246581 View attachment 246582
Hey man, thank you.
Your translation only had one error, a small one. 'Pens' are for writing, putting ink to paper. I think you meant 'pins', as in hinge pins. Overall though, the translation was great; easy to understand.
I hope this helps you a little.
joe
Koser
Russia
Thank you for your rating!
"Nothing is so cheap and not as expensive as emotions"
Durobans
