Where to install Additional Gauges ??
Foggy
KS
I have a wideband oxygen sensor and gauge to install and also
am thinking of doing a boost gauge now that my supercharger is in...
My rear O2 sensors are disabled thru tune, so I'm thinking the passenger side rear O2 bung
for sensor... for that
Where is the best place to run wiring thru to interior for extra gauges ????
any suggestions on a boost gauge too.. I'd like to do an electric gauge with map sensor
and a readout that shows vacuum and boost - but i'll never have over 10Lbs so don't need
one with a crazy numbers !
Tom
Multnomah Falls
Military
I have seen many a gauge set be mounted to the "A" pillar. I have seen gauges under the dash but they would be in the way for me.
F
Foggy
KS
Where are people running the wiring thru the firewall ????
F
Foggy
KS
Got around to doing my AEM wideband oxygen sensor gauge tonight...
It worked for a minute !!! I'll have to call AEM in the morning to see WTF
Have another question : Where is the best place to get switched power from
my fusebox in the interior??? All of mine seem to be HOT even with key off/out..
And the rest only go hot when using the actual item they control..
I figured my rear wiper fuse would be good option, but it's hot all the time.. WTH ??
St. Louis
The outfitter box to the left of the brake pedal has ground, switched power, RAP (retained accessory power), and constant power. Someone has a pic here somewhere showing what terminals are what.
EDIT: Check out the pics in this post
https://www.tahoeyukonforum.com/index.php?posts/1345700
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
juniordaboi909
