Want to do a trans filter and fluid change....
St. Louis
Is there a kit that I can order that has the correct filter and fluid, or do I need to get it all seperately?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Multnomah Falls
Military
Have never seen a kit like that. Dexron VI for the fluid and a quality trans filter kit from RA. I was able to get them both at Amazon when I ordered mine.
gooffeyguy
St. Louis
How many quarts of fluid is needed? And did you use the "disconnect cooler return line" method to pump some out before dropping pan?
2001 Yukon SLT
Multnomah Falls
Military
I have a drain plug on my pan so it was all drained before the pan was dropped. You can buy those pans to be able to do that. I bought 2 gallon jugs of AC Delco Dexron VI and added as needed. I think I used close to 5-6 quarts. That is a guess. I did not flush because I had no problems before and did not want to chance the clutch material being blasted with all new fluid. I have heard of and seen when that problem occurs.
Multnomah Falls
Military
Dealers can be a finicky bunch. Find a local qualified independent shop that you like and stick with them. I have never had any work done at a dealer, in over 40 years, unless it was a warranty.
the blur
Cyber Space
I would like to add a drain plug, like my 2003 had. Do they make a pan with a drain plug, or is it a mod only ?
wjburken
Eastern Iowa
2001 Yukon SLT
If it’s your 2012, I believe you need 6 qts. This is based on what I found in my research as I am going to be doing this soon.
Dlshort21
