2017 Yukon vs 2017 Tahoe
dsh1106
39.7594° N, 84.1917° W
Hi All
Question for those out there who know more than I ...
Backstory:
I have both of the above mentioned vehicles, both are equipped with 5.3L engine, the Yukon is a SLT and the Tahoe is an LS.
My question, shouldn't both of these vehicles react the same, power wise while driving? I'm experiencing a huge difference in overall driving in the throttle response as well as AFM and the shifting up through the gears.
The Yukon's throttle response is so much better and I can never tell if the AFM is on or off, and the shifting is flawless, if feels great. The Tahoe has terrible throttle response, it seems to shutter while progressing through the gears and the RPMs are all over the place while driving in town. Highway driving is flawless.
The Yukon has just shy of 36K on the clock
The Tahoe has just turned 23K on the clock
Trans fluid looks good in the Tahoe and there are no strange sounds coming from the vehicle.
Any input would be greatly appreciated.
Thanks
Scott
BlaineBug
Does the Yukon have the integrated trailer brake controller as well as two-speed transfer case with low-range? That would indicate that it had a lower gear ratio than 3.08.
My 2019 has 3.08s and I really can't say I've experienced what you have described, however.
D
dsh1106
They do have different ratios:
Yukon - RPO code - GU4 3.08 axle
Tahoe - RPO code - GU6 3.42 axle
This info didn't help answer my question ......
D
dsh1106
Yukon is a doesn't have the trailer brake...
BlaineBug
Ok, so the Yukon doesn't have the towing package, but the Tahoe does?
BlaineBug
No, I don't think it would. The throttle response should be the same, but with 3.42 gears vs. 3.08 the Tahoe should actually feel "peppier" in regards to the acceleration rate.
