04 yukon awd lowering tips?
jeffreycobra
North West Indiana
Any key tricks to make the process any easier ? Auto ride is removed and replaced with regular shocks! Wanting to get her nice and Stanced
live2pull
Phoenix, Az
belltech 2508 drop spindles, belltech 34324 rear springs, shock extenders. DJM rear sway bar relocation kit. free travel mod. move bumpstops to axle. 2 inch front, 3/4 drop rear.
Big Mama
Virginia
Keep in mind if you’re going to bigger wheels later. The 2/3 kit works with most any combo. The 4” rear seems to make the rear look lower. Good luck and post pics.
ddwelch
Looking at the belltech 34324 rear springs you mention, the part number provided brings up 07-19 rear spring set. Is that correct being the original posters vehicle is 04?
(Learning here, hence the question)
live2pull
Phoenix, Az
I am 99% positive springs fit across GMT800-GMT900 platforms
Byoung1330
Cookeville tn
I have mcgaughys drop spindles. Stock keys turned down. The rear I have crown 4 inch drop coil. Spohn panhard. djm rear links and control arm relocation brackets. Had beltech sp shocks just went to bilstein 4600 . Like them better. Except length of rear shocks. and I have 305 35 24
briannorris
