210K miles on 2008 Tahoe. Replacing O2 sensors
pacem
In my experience O2 sensors slowly go bad and to the best of my knowledge, these haven't been replaced at 210K miles. Question, do I need to replace all 4 or just the front 2? FWIW, I am not getting any codes, but MPG is poor even for a power tune. They are called upstream and downstream. I assume front ones are the upstream.
wjburken
Eastern Iowa
I would recommend replacing all 4 sensors.
Yes, Upstream is before the Cats, Downstream is after the Cats.
You may also have a Cat failing as well.
P
pacem
I see. I am getting them off rockauto. I assume the front ones are identical, as are the rear? Here are the part number:
DENSO 2344668 {Click Info Button for Alternate/OEM Part Numbers} Info
Upstream
$25.79
Add to Cart
DENSO 2344256
P
pacem
understood. meaning upstream left is identical to upstream right, and same for downstream.
P
pacem
In my experience with other GM products, they get 'lazy' as early as 100K, and I have 210,000 on the clock.
GMT800 2005 Tahoe Z71
Navy Supporting Member
You are right about both upstream being the ones before the cats, left and right. Time was when Oxygen sensors were recommended for replacement at 100k miles. The fronts are monitoring the exhaust mixture from the engine and the rears monitor the catalytic converter efficiency. Lazy/failing fronts will change help air/fuel mixture and therefore fuel mileage is effected.
trailblazer
Is there a definitive way to know if they have failed? I’d like to know this before I just start replacing them.
This should keep you busy for a while: Keep this in mind though, it can test good now and your replace 1 or 2 sensors to save money and then next week, because of the sensor age, the other 1 or 2 can go bad.
Learn How to Check an Oxygen Sensor
Learning how to check an oxygen sensor (O2) will help you confirm a potential problem with the sensor in your vehicle before you spend time and money replacing a unit that might not even need a replacement in the first place. Oxygen sensors detect the amount of oxygen content in the exhaust stream and turn this information into a voltage signal that your car computer uses to control fuel ratio and emissions.
However, whenever the sensor’s signal changes—and stays out of—its normal operating parameters, it causes the computer to store a trouble code in memory and turn a malfunction indicator light (MIL) or Check Engine light on your dashboard to alert you of the problem.
Still, whether you suspect a bad oxygen sensor or a computer trouble code points to a potential issue with the O2 sensor, the problem may lay somewhere else. All the computer does is inform you where the problem was detected. For example, you may have a loose or torn vacuum hose, causing the sensor to read a constant high rate of oxygen in the exhaust stream; or the sensor electrical connector may have become loose, preventing the device from working. Instead, the computer detects a sensor abnormal operation.
So before replacing the unit, you can use the sensor’s operating characteristics to verify whether you actually need to replace it.
Connecting Your Voltmeter to the Oxygen Sensor
To run this test, you will need a 10-megaohm impedance digital voltmeter. Most digital voltmeters come with a 10-megaohm protection to prevent the meter from drawing too much electrical current and damaging electrical or electronic components during a test.
Also, before you start your tests, locate the oxygen sensor you want to troubleshoot. On pre-1996 vehicle models, you'll find the sensor usually on or near the exhaust manifold. On 1996 and newer models, you'll see a sensor near the exhaust manifold, and another one near the catalytic converter. However, some vehicle models have up to five or more sensors. Make sure you know which sensor you need to check.
When you retrieve diagnostic trouble codes (DTC) from your car computer, you may also get information about the specific sensor at fault, depending on your scan tool features. For example, you may get a Bank I, sensor 1 at fault, which points to the O2 sensor on or near the exhaust manifold on the cylinder head that contains cylinder number 1. A bank I, sensor 2, points to the sensor on the same side but farther down the exhaust system, probably right before or after the catalytic converter. The same goes for the other cylinder head—on V type engines—which is considered Bank II.
To locate Bank I and Bank II, consult your vehicle service manual, if necessary.
Then, if the sensor you're testing has more than one wire (heated sensor), locate the signal wire by consulting your vehicle service manual, if necessary.
  • A single-wire sensor uses that wire as the signal wire.
  • Two-wire sensors use one wire for the sensor's signal and the other one to power the heater.
  • Three-wire models, use one wire for the signal and the other two wires to power and ground the heater.
  • Four-wire sensors, though, use one of the wires to ground the sensor itself.
To identify the wires look at the wiring diagram in your vehicle repair manual. If you don't have the manual, buy an inexpensive,
ir
aftermarket manual for your specific vehicle make and model at your local auto parts store or online.
  1. Once you have the appropriate voltmeter on hand and have located the sensor, warm up your car engine to operating temperature. You can do this by taking your car for a 20-minute drive on the highway or idling the engine for about 15 to 20 minutes at a fast idle speed.
  2. Turn off the engine and set your voltmeter to the mV (millivolt) DC scale.
  3. If you are testing an O2 sensor near the catalytic converter, lift your vehicle using a floor jack and safely support the vehicle on a couple of jack stands and block the rear wheels.
  4. Be careful when connecting your meter. When the engine is at operating temperature, the exhaust manifold and pipes are extremely hot. Don't burn yourself and keep your meter and probes away from hot surfaces.
  5. On sensors with one to three wires, connect the meter’s red probe to the sensor's signal wire and the meter’s black probe to a good ground on your engine. On four-wire sensors, connect the meter's black probe to the sensor's ground wire. If necessary, consult the wiring diagram in your vehicle repair manual.
To connect your meter's probe to the wire, use a wire-piercing probe or back probe the sensor through the connector. With some sensors, though, it's difficult to back probe the signal wire through the connector. To overcome this limitation, you can unplug the sensor and connect a strand of copper wire to the connector prong for the signal wire, and plug back in the electrical connector, leaving the stretch of wire sticking out of the connector. This will give you a bare wire you can connect to your meter probe for the test. Just make sure the bare wire doesn't touch ground.
Another option is to pierce the sensor's signal wire through the insulation with a pin and connect the meter probe to the pin. But keep the pin from touching ground.
If you decide to go with the latter method, after you finish your tests remove the pin and cover the pierced section of wire with electrical tape to prevent moisture and corrosion from creeping into the wire.
Reading the Oxygen Sensor’s Signals
Start the engine and check the sensor’s voltage signals on your voltmeter. The sensor voltage should cycle or fluctuate within the 100 mV-900 mV (0.10 to 0.90V) range approximately. This means the sensor is operating properly.
If the O2 sensor only produces a low- or high-voltage signal, either you have an engine performance issue or the oxygen sensor stopped working. To verify sensor operation, conduct the next two tests.
Test the Oxygen Sensor Response to a Lean Fuel Condition
  1. First, disconnect the hose from the positive crankcase ventilation (PCV) valve leading to the intake manifold. This will allow more air to enter the engine. If you need to locate the PVC valve, consult your vehicle service manual.
  2. Check the sensor’s signal voltmeter reading. An oxygen sensor interprets an increase in oxygen as a fuel lean condition and emits a signal close to 200mV (0.20 V). If the sensor doesn't respond accordingly or takes time to respond, the sensor isn't working properly.
  3. Reconnect the hose to the PCV valve.
Test the Oxygen Sensor Response to a Rich Fuel Condition
  1. Disconnect the plastic duct from the air cleaner assembly on your vehicle.
  2. Block the duct opening leading to the engine with a clean rag. This will reduce the amount of air going into the engine.
  3. Check the sensor’s signal voltmeter reading. An oxygen sensor interprets a decrease in oxygen as a rich fuel condition and emits a signal close to 800mV (0.80 V). If the sensor doesn't respond accordingly or takes time to respond, the sensor isn't working properly.
  4. Reconnect the air duct to the air cleaner assembly and turn off the engine.
If the oxygen sensor in your vehicle responded correctly to your tests, you might have a problem with another component affecting fuel efficiency. The engine may have a vacuum leak, a problem in the ignition system or something similar. If your sensor didn’t respond properly to your tests, the sensor has stopped working and you need to replace it.
trailblazer
So if I never get a MIL regarding the sensors, it’s safe to say they are fine for now? If I were to get a MIL I’d probably replace them all.
wjburken
Eastern Iowa
That’s what I would do. My 2007 Denali with the 6.2L went 300K in original O2 sensors.
Of course, totally your call. Lots of fuel mileage can be wasted before the readings get out of parameters and turn on the MIL. Plus, by that time, catalytic converters that are good now, may well get damaged before the MIL comes on. I consider oxygen sensors as a maintenance item. I never wait till I have a misfire to change plugs and wires. I never wait till I am dead alongside the road before I replace the fuel pump, fuel filter and relay. I never wait till I have a no crank situation before a battery replacement. Again, your call.
trailblazer
Seems like if “lots of fuel mileage will be wasted” then there should be a MIL or noticeable reading.
I am talking about accumulative over time. If it gets drastic and out of parameters then yes, the MIL should come on. If is gradual and keeps the MIL light off but is still doing damage to the cats with the wrong stoichiometric ratio, air fuel mixture of 14.7 to 1, but may not be far enough out of parameters to turn that light on. We have had members complain of loss of power and was related to bad cats but they never did see a light on. I guess I am just paranoid about that. I would rather replace sensors when I know the cost and can plan it instead of having to do sensors and cats and be surprised. I don't run shops anymore so I am not selling to anyone. I am just offering my opinion.
Seamus
Palm Beach
They should be changed at 100K. Yes expensive but your paying for it in fuel. Also if out of spec they can hurt your cats. Which of course is more expensive. I just did all 4 on mine at 94K as 1 was bad. I too bought from rock auto and bought AC Delco. Happy I did. They have the exact length wire and GM clips that hold it in the stock spot perfectly.
Plus you could plan on the repair and the cost. No surprises. Plus, great protection for the expensive cats.
P
pacem
--------------------------------------------------------------------------- I like that approach.
j_jerry79
