JonnyTahoe
Should be fixed now.That response got messed up real quick. It is not part of the quote.
rhodium hit $12,700 oz$250 for scrap? Really? That's almost more then I paid for the new ones. lol
it went from 300$ to 13k in a couple of months
1 gram is worth 400$ or so
3way cat right??
palladium, platinum and rhodium are used in cats = $$,$$$
GM bread loafs are worth Big BUX
if i sell mine right now i can break even
20854453=EPA only
20854454= CA state worth slightly more
what is the part number you have a single one is worth 150 to 360$Wow! How would I sell mine? I've seen a few guys on Facebook offering to buy them, but what's a fair offer?
Where are you getting these figures from ?rhodium hit $12,700 oz
3way cat right??
20854453=EPA only
You can get a friend to help you that is mechanically inclined. Get him/her to have about 5-6 shop towels or even home towels in their hand and while you are under the rig have them, with the engine at idle, hold the towels over the end of the tailpipe for a few seconds at a time. The pressure will build and they will have to pull the towels back every few seconds. The immense back pressure will force the leak out under a higher pressure and you can feel for where that will be with your hands. Check the obvious new attaching points. Both of the attaching points at the front of the cat converter y-pipe, the rear attachment of the same pipe and the bracket area of where you just fixed or patched that broken manifold stud. You can check that place from top and bottom. During those few seconds you should feel the exhaust pressure with your skin. Don't touch the hot spots of course but just get close and feel for the pressure. It may also be in a spot that was there before but unnoticed.
Well, I'm happy to report it's not carbon monoxide. My detector came and I left in the running car for about 10 minutes and it came back with 0 PPM. I really don't think I have a leak but I'm going to test it as you suggested above anyway. I was under it last night it all looked great. Let's just hope I'm getting the flu.
Thanks again for the suggestion Ron!
But why is the problem only when you drive your rig? You have done so much to improve that rig it should be very happy and keep you safe instead of causing you to feel sick.
That's the same thing I am thinking but this seems like a lot of driving to burn all that off. If that was the case, I would have had customers drive vehicles home after I did repairs that complained of the same thing. I didn't.
