Catalytic Converter...
BG1988
$250 for scrap? Really? That's almost more then I paid for the new ones. lol
rhodium hit $12,700 oz
it went from 300$ to 13k in a couple of months
1 gram is worth 400$ or so
3way cat right??
palladium, platinum and rhodium are used in cats = $$,$$$
GM bread loafs are worth Big BUX
if i sell mine right now i can break even
20854453=EPA only
20854454= CA state worth slightly more
mijohnst
mijohnst
3way cat right??
20854453=EPA only
Wow! How would I sell mine? I've seen a few guys on Facebook offering to buy them, but what's a fair offer?
mijohnst
mijohnst
Some guy on Facebook said he'd give me $150 for both of mine. I sad, "pass.." but I have no idea who to sell them to. My PYP place doesn't want them. I don't know what model mine is but they're original to my 2005. I can't seem to find a number on them. I'll look again tomorrow.
mijohnst
mijohnst
Another question for the experts. I think there is something wrong with the catalytic converter I installed or the exhaust system. After getting it buttoned up this weekend I've been driving it and I've been noticing that after driving it I'm kind of dizzy. I thought that maybe I was getting sick with the flu or something. But after a while, I go back to I feeling fine. This morning I was completely fine until I got to work and again...dizzy. (I am rolling the windows down when I start to feel it)
Suspecting I have a leak somewhere I crawled up under it last night and I don't hear any noises or feel any exhaust leaks at the joints. No smoke coming out of the exhaust manifold, muffler or O2 sensors. I ordered a carbon monoxide detector yesterday and when it comes in today I'm going to run the car with it inside (with me NOT in it) and see if it's that. Anything else I should look for or look at? I've never had a problem like this and this didn't start happening until after I just replaced those converters.
GMT800 2005 Tahoe Z71
Navy Supporting Member
You can get a friend to help you that is mechanically inclined. Get him/her to have about 5-6 shop towels or even home towels in their hand and while you are under the rig have them, with the engine at idle, hold the towels over the end of the tailpipe for a few seconds at a time. The pressure will build and they will have to pull the towels back every few seconds. The immense back pressure will force the leak out under a higher pressure and you can feel for where that will be with your hands. Check the obvious new attaching points. Both of the attaching points at the front of the cat converter y-pipe, the rear attachment of the same pipe and the bracket area of where you just fixed or patched that broken manifold stud. You can check that place from top and bottom. During those few seconds you should feel the exhaust pressure with your skin. Don't touch the hot spots of course but just get close and feel for the pressure. It may also be in a spot that was there before but unnoticed.
JonnyTahoe
Minneapolis
3way cat right??
20854453=EPA only
Where are you getting these figures from ?
mijohnst
mijohnst
Well, I'm happy to report it's not carbon monoxide. My detector came and I left in the running car for about 10 minutes and it came back with 0 PPM. I really don't think I have a leak but I'm going to test it as you suggested above anyway. I was under it last night it all looked great. Let's just hope I'm getting the flu. ;)
Thanks again for the suggestion Ron!
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Inner ear infection causing mild vertigo????
But why is the problem only when you drive your rig? You have done so much to improve that rig it should be very happy and keep you safe instead of causing you to feel sick.
That's the same thing I am thinking but this seems like a lot of driving to burn all that off. If that was the case, I would have had customers drive vehicles home after I did repairs that complained of the same thing. I didn't.
wjburken
Eastern Iowa
One thing to keep in mind is a moving car has much different air flow paths than a parked car. Sitting in an open area parked will not simulate the air flow you have when rolling down the highway.
In addition to what Ron suggested, make sure your rear hatch is latched all the way. Also, might put the CO detector in the car while your driving and see if the readings are different.
mijohnst
mijohnst
Well, I'm still having this issue where I drive it and I just feel a bit dizzy and crappy. It's been driving me crazy and makes me not want to drive it. It's not carbon monoxide but I still don't know what it is.
Today I started looking at the part that I ordered and I'm hoping I found my answer. I had bought it on my phone after clicking on the link that Ron put at the beginning of this thread. The phone being small and all I didn't notice that he linked a converter for a 2002 Tahoe. Mine is a 2005 and it bolted right up but a Walker 50511 says it's not compatible with my year. That's all I can think it is. It's totally my fault again for being too eager....again!
So do y'all think? Is it possible that the wrong part could cause this?
varminpoolteam
