What did I break
Brady1287
So I went to check out my wife's throttle body because it was making noises. In the process of doing it in the dark I broke some line that comes from the passenger side valve cover area into the air intake right before the throttle body. It's a 09 and I can not find the part for it. I keep seeing PVC tubes when I google it but then it says it wont fit. It's a 09 tahoe hybrid 6.0. Thank you in advance
It’s the “clean side” of your PCV system. There’s a hose that connects your passenger side valve cover to the intake before the throttle body that creates a vacuum due to the air entering your TB. Not sure what they call that hose but it is part of the PCV system.
drakon543
that line can be swapped out for a rubber hose in the mean time until you get the correct one if you want to keep it stock looking under there.
B
Brady1287
Thank you for the replies everyone. I will get a picture after work. Thank you for the information and I like the idea of the rubber line until I can find the name of the part
B
Brady1287
Somebody found the part number. I'm 99 percent sure this is it
B
Brady1287
From my description that should be it right? I cant seem to find a good shot of the two connector ends to know for sure
GMT800 2005 Tahoe Z71
Navy Supporting Member
I hope so. You may not know for sure till you look deeper. I am just glad Rocket Man came up with the correct description. I had no "freakin'" idea till he chimed in.
No. The purge valve is on the vapor canister which is at the opposite end of your truck, back by the gas tank. I’ll see if I can locate the right part.
Watch this YouTube, it’s the same hose as the one you’re needing. All I found on the parts sites was the pcv valve side. GM Parts giant even called it the “dirty air” side. You want the “clean air” side. Edit: this is on a NBS. See post below for your part number.
B
Brady1287
Buford bubba
