Load range E. What does the sidewall air pressure say? That is for a load condition. Run it 10 psi otherwise. Too much air will wear the center of tire out first. Too little air will wear the edges out first.
What psi range should I be running unloaded and stock?
Correct.What is the tire rating, 80 psi @ 3195 lbs?
