Maybe, I installed the shift motor, TCCM and transfer from the same vehicle. Everything worked perfectly for me. Of course I also installed the new dash switch too.
If it is telling you to "service 4 wheel drive" my guess is, it is not be shifting correctly, a bad connection, the TCCM or a shift motor. If you are near Reno we could swap parts and narrow it down...
You probably know this but, I will say it just in case..
When shifting the transfer from High to Lo or Lo to High or Neutral to High. The transmission should be in N and it should be moving at less than 3 mph or stopped. (Transfer in N you can shift right into High 2 or 4 high)
When I do my shifts most of the time I just stop, put transmission in N then shift transfer and wait a few seconds. When light stops blinking I shift the transmission into drive and go on..
Shifting from 2-High > Auto > 4-High > 2High can be done on the fly at any speed with the transmission in gear.
