Rear tires rub with 24s.
I have 24s on my 07 tahoe and every once in a while when i go over bumps or around tight corners they rub the inner fender. I have cut a little where it rubs but i dont want to tear the whole thing up. Does anyone have any other suggestions?
Nickleahy23
Portage/Menomonie, WI
mine rubbed in back as well...give it a week or 2 they will rub the plastic enough to where it doesnt make any sound..it wont hurt anything either
Conor
"Bob's your Uncle"
Seattle, WA
What is your offset on the wheels. If anything should rub, it would be the fronts. My Momo's rubbed a little in the front of my Escalade and I had to cut some of the fender liner out.
M
Im pretty sure its a 40mm offset, It only rubs when the shocks compress. Like when im towing a boat so it would take a while for it to wear down.
BOSS
The People's A D M I N
Dallas
I would space the wheels out, start with 1/4in. and see how it goes. Doesn't sound like you need much. My rears are 1/2in. spaced out and made a big difference...problem is I already cut out alot of plastic and now I gotta go buy a new set.
BOSS
DwDrummer
AL
If you have the Boss 330's in 24's you have a +30mm offset, I have the same wheels!:)
M
No they are 313s, and i have thought about spacers i dont even think i would need 1/4 inch. It barely hits, just enough to make noise.
Nickleahy23
its not that big of a deal..i mean ya it sounds annoying as hell..but mine went away after a week..worst case pop the wheels off and trim exactly where its hitting
DwDrummer
AL
You can get wheels in different offsets.
This I know but for the this particular style ( Boss 330 ) wheel it's available in only +12 and +30m for 24x10 in the 6x5.5 bolt pattern. The 313 was offered in a +40mm.
JasonW4141
