Brake light info.
992dr
Eastern N.C.
I have lost track of how many passenger brake light bulbs I have replaced in the past two years.
It's only been the passenger side and that has a new harness as well.
Has anyone else had any issues with brake lights blowing out?
A mechanic told me the harnesses are a common issue? Is this true as I have never seen anything about it before?
Should I look at LEDs to replace the factory ones?
Thanks
drakon543
do you ever notice moisture inside the taillight housing? that can definitely cause premature bulb failure
BG1988
Thanks
have you been using 4157(universal CAR/Truck) bulbs? or 3157(for cars only)
Yeah Sylvania bulb seem to be the best
3157 is only rated for 12-vDC
4157 is rated for 14-vDC
I have these but I have not put them in yet (for the signal though)
as i have Factory LED brake lights
https://www.ebay.com/itm/Sylvania-Z...623930&hash=item2ceb144803:g:N1IAAOSwAmFc4rll
kbuskill
NE. FL.
I would check and clean the ground under the truck where the harness goes down and bolts to the body.
992dr
992dr
Eastern N.C.
Just got back and no condensation.
Hmm, I've been using Sylvania "longlife" 3057 bulbs.
Have I been using the wrong bulbs? This is what was recommended if I remember correctly.
I will do that as soon as I get home tomorrow.
BG1988
3x57/4057 is for cars 4157 is for trucks/SUVs with Krypton gas (blinker fluid)
992dr
992dr
Eastern N.C.
I'll be picking up some new lights tomorrow as well as checking and cleaning the grounds :)
It does exist? I knew it, and now I know where to find it ;)
BG1988
you should check your Engine Fan fluid as well
992dr
992dr
Eastern N.C.
OK, went under and couldn't see where the grounding strap was. Felt along the harness up through the spare tire area and couldn't feel anything coming off the harness.
Do you have a schematic or any idea where it would be?
Thanks
kbuskill
NE. FL.
Thanks
I don't have a schematic... I thought it was right there under the truck at each corner... but my memory may be a little fuzzy.
992dr
992dr
Eastern N.C.
I'm due for my inspection and have been neglecting this brake light mess. Went out just now and put a new bulb in and it popped instantly. What's weird is the parking light stays on. Its just the brake light that pops.
This is the same side I replaced the harness about 5 years ago.
Someone mentioned to me that harnesses can go bad every so often. Is this true? If so, I may order another one tonight.
BG1988
the bulb is acting as a FUSE.
your running a lot of current threw it that is why it's popping "instantly" you have a wire problem elsewhere..
and the parking light being ON, your grounding something else .. that is not pulling much current to pop the fuse aka the filament..
so the light bulb is acting as a ground path with high current on the brake light circuit .
so you have
a shorted brake light circuit.( that is shorted as a ground path for a high current device)
maybe a mouse got to your wires ..
992dr
992dr
Eastern N.C.
Have you measured the voltage for both the running and brake light circuits?
I have not. I actually have no idea how to hah. I don't anything about electrical.
so you have
Sorry if this sounds stupid but, does this mean that there may be a few wires exposed and all touching each other?
Sounds like I have to go tracking some wires this weekend.
BG1988
possibly a few got chewed up... and it's crossing wires do you happen to have any other issues ?
992dr
992dr
Eastern N.C.
As odd as this may sound, no other issues.
This issue started when I cut my resonator off and melted the original harness. After I replaced it with a new harness, bulbs started to pop. This has been going on for three years actually. Only reason I remember is, its always out when I get an inspection. They put a new bulb in every time. I was trying to beat them to it this year haha.
BG1988
maybe more was melted elsewhere?
JeffK
