Upgrade transmission recommendations?
Sam Harris
Ok all, I know my transmission is not going to last forever. I also felt a slip while driving the other day.. [emoji3525] I guess my BB tune will have to wait a bit. So, I’m looking for your recommendations for a good, reasonably priced upgraded transmission and torque converter. Currently just stock motor, with MIT intake and ARH longtubes. I’ll be tuning ASAP, and likely a stage 1 or 2 cam when I can. Someday, I’d like to supercharge her if it’s in the cards, but that would be down the road. So I’m looking for just a bump over stock that can handle a decent HP increase. I’m thinking I like the Cahall performance transmission here: https://cahallperformancetrans.com/4l60e,-65e,-70e
and likely their recommended protorque converter at probably stock stall speed.
Any recommendations, or places to stay away from are much appreciated!
Sam Harris
Sam Harris
Hmm, 03 Yukon right? 4 speed auto. First thing that rings in my mind is can it be swapped to the NNBS 6 speed auto for better mileage, drivability and longevity.
Yessir. That would be sweet.. however, I’m looking for as cost effective as possible. I also believe if the 4l60e is properly built it should have no problem holding up to a couple hundred HP / TQ increase.
Sam Harris
Sam Harris
HiHoeSilver
Away!
Chicago
I think @Rocket Man is running Performabuilt.
randeez
south florida
6l80 would need a stand alone with gen3 ecm would prob count that out.
there are still a few people/companys doing r&d for the 4l60... not so surprising since its found in so many cars/trucks but i dont know how budget minded its going to be to get one to hold a lot of hp compared to a relatively stock 4l80.
80e would need different transfer case and a little bit of wiring changed.
Sam Harris
Sam Harris
Thanks @randeez. I’m not looking for any huge hp increases right now. I figure an extra 100-150-ish tops.. I mean, I’d love to build a turbo, built 427.. but for now I’ll have to live vicariously through your build. [emoji16][emoji106][emoji631]
randeez
south florida
As long as you also feel the struggles <3
Nah what I mean is a used low mileage 4l80/converter/flexplate $1000, some wiring (free or $150 for swap harness), transfer case can be found under $500, drive shaft mods will be another couple hundred.
$2k doesnt buy a very built 4l60, or maybe it does? Dunno havent looked into them much
SDHanz
