Light bar behind grill installation
2010gmcyukon
Midwest
I've seen some led light bars installed inside the front grill on here lately. I'm hoping anyone can share pics of how they mounted those in there?
kbuskill
NE. FL.
Here is mine on my Burb.
42" curved 800 watt.
Mine barely fits between the headlight housings but I wanted the full width look.
Hope this helps.
2010gmcyukon
2010gmcyukon
Midwest
Hope this helps.
Ok so you just mounted it to that support piece behind the bumper. That seems reasonable. I got a shorter 20" bar so I'm hoping I can do that without removing everything.
The_Burban
This is all I did. Right atop the energy absorbing styrofoam. It has held in for thousands of miles . You could drill into the bumper.. or drill through a do a bolt/nut setup.
I didn't remove the front either. Just snuck in, peeling the grill back to gain access.
R3cord303
Posse In Effect
Oregon Valley
Shimmy23
WA
how do you plan to accomplish this effectively with a yukon? our grill is very different than the tahoes. I haven't seen a aesthetically pleasing install on a yukon yet.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I had this in my last truck and long term plans are to put one in my current Tahoe behind the grille before I die. Do they make lighted cab visors for our rigs? I'd like one of those too...
St. Louis
Is it legal to have red lights on the front of a vehicle in your area?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
89Suburban
SE PA
2001 Yukon SLT
No it isn’t. I’m a major KITT nerd so I had to do a red one at the time to get my fix. Definitely did not use it on the road. Just off road or on private property or at car shows.
If there was enough of a gap under my current Tahoe’s rear tailgate I would have kept it. It has multiple patterns to choose from. Next one I get for the front will be orange.
89Suburban
SE PA
Here is the guy that makes them. Last half of the video shows all the patterns the controller can do. Which also has LED display so you can see what it is doing inside the vehicle. He can make any custom size and colors.
Erock7625
East Texas
Did you ever get this mounted and how did you do it? Trying to do the same on a 2011 Yukon, only options are to somehow mount it to the styrofoam or move it back a bit and mount it to the plastic behind it.
2010gmcyukon
2010gmcyukon
Midwest
Yeah I ran some long screws into the Styrofoam. It felt pretty steady, and I figured the grill should protect it from impact that would knock it loose.
Erock7625
East Texas
Finished mine finally, I mounted it behind the grill using concrete tapcon screws into the foam. The tapcons are thick and have lots of protrusions to grip better, that worked pretty good but I wanted it to hold better so I used some JB-Weld under the mounting bracket to further secure it to the foam. I then ran the wire to the battery, mounted the solenoid to the fender and ran the other wire across the back of the engine bay and through the door hinge and into the dash panel. I then drilled a hole in back of the empty spot and luckily the Nilight switch I bought fit perfectly snug in the opening.
View media item 28545View media item 28560View media item 28556View media item 28559
2010gmcyukon
2010gmcyukon
Midwest
Looks Good!
Sundancer
Army Law Enforcement
Long Island, NY
Great looking work on all these trucks ! I am dying to install this on a 2011 LTZ but I dont have a clue on the electrical connections at all.
13UpInSmoke
Think mines a 20". Installed the switch in the small pocket next to the light switch. Made a couple brackets to bolt it to the core support/trans cooler mount
GS Audio
