Seat Position Memory Loss
woody3250
My front driver seat keeps losing its position memory. Sometimes when switching between driver 1 and driver 2 the seat will move all the way forward as if that's the position that was stored in the memory. Has anyone else had any problems similar to this? Any ideas on what might be happening? Thanks in advance.
BTW its a 2003 Chevy Tahoe Z71 5.3L V8
TheYuk
Atlanta
my 04 yuk does this but the seat goes all the way back. not sure why
DenaliAK
Colder than you
Alaska
Are you using the factory FOB's? As soon as I switched from them to my new alarm/auto start it lost the memory function because it uses the FOB to ID the driver.
Kind of annoying, actually. I can manually press 1 or 2 on the door, but even then it doesn't always remember settings.
NJ04HOE
Paterson, NJ
Mine has never remembered the settings for more than a few hours so I just stopped using it a few months after buying the truck.
Sent from my iPhone 4 using Tapatalk
UBILLN
yeh this plagues most of us, just turn off the feature and then it will stay where you put it last regardless of whether you use the fobs or not
W
woody3250
No, I'm actually using factory FOB. Interesting, but it's good to know I'm not alone. Thanks for the replies.
dcogswell
I read somewhere the dealership can "flash" or "update" the memory for this unit. Currently, the button for moving the seat forward and backward is working in opposite. Also, the memory is not working and my drivers side mirror has to be corrected every time I drive. So, one of these days I'll take her in to get "flashed" or whatever the need to do to it.
RobertWYoung
Fort Worth
It is strange my seat forgets its settings but the mirrors always work, I have the backup assist on my passanger side mirror to help backing into the garage.
1fatho
Alaska
Hahaha YEAH BUDDY GO 2003 Zs! Mine has the same problem, I like it when it "ghosts" me and moves it to a spot that I havent selected.
mo2058130
Same problem here did you ever get it fixed was it just a simple trip to the dealer thanks
GMT800 2005 Tahoe Z71
Navy Supporting Member
This happens on mine as well. 02 Tahoe. I know thread is old but about 3-4 times a year the seat lumbar or position will have changed and it can happen when parked. What is the procedure to turn it off. I have the factory FOB.
Drewphil
