Group 65 battery in my burb?
Derick
Indy Suburbs
Have the opportunity to get a nice duralast gold battery at a discounted price. It looks like the specs call for a 48, but this is a 65....will it fit? Seems like the size is pretty close, I think the width is a hair larger.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Compared dimensions:
Group 65 Batteries-L-12 1/16 W-7 1/2 H-7 9/16
Group 78 Batteries- L-10 1/4 W-7 1/16 H-7 11/16
BG1988
if that price is not less then $119.99 it's not a good deal
Flooded H6 3 years 2 years prorated
AutoZone
$177.99
Walmart
$119.99
AGM
AutoZone (3 years free replacement 2 year pro rated)
$217.99
Walmart(5 years free replacement)
$149.99
They are both made by the same Manufacture as well even the housing is the same and same manufacturing plant.
except for the warranty on the AGM walmart offers 5 years replacement instead of 3 years
AGM = 760CCA
flooded =730CCA
H6 = group 48
10.90 x 7.00 x 7.50 Inches
Group 48= 11.9 (might be over hang or something?)x 7.5 x 7.6 inches
Get an H6 battery :)
petethepug
Michael
SoCal
Bosch Platinum Series AGM Battery Group, Size H7/L4/94R Typically $145 when on sale 25% off. Won’t crap out due to extreme hot/cold. Made by Varta in USA. Use them in all our cars now. Optima’s quality went down the toilet since Johnson Control purchased them and moved factory to Mexico.
The Bosch kisses the coolant overflow tank but fits like a glove for 800 CCA and 4 yr nationwide over the counter, no questions asked replacement. Doesn’t leak if your alternator fails and overcharges it.
https://www.pepboys.com/bosch-platinum-series-agm-battery-group-size-h7-l4-94r/product/838845
jeffbco
Bosch also has the AGM battery in the correct H6 size...looks like Pep Boys stopped selling these so not sure the best place to get. I've had great experience with the Bosch AGM.
Derick
Derick
Indy Suburbs
Well I got (2) like new batteries for a total investment of 110. One is a duralast gold 880CCA, and the other is interstate 675CCA. Both have date codes within the past 2 or 3 months and tested good at the local oreilllys. I'm going to do the dual batteries...because why not. The specs are 1/2 wider, I'm sure I can make something work.
kbuskill
NE. FL.
Keep us posted on fitment, please.
Do you plan on using an isolator?
Derick
Derick
Indy Suburbs
I don't know on the isolator..... I don't have any electronics or bumpity bumps to protect.... So my gut is that I'm going to just run the cables to the main battery and that's it.
Derick
Derick
Indy Suburbs
Just an update on this, I wanted to reply to my original thread but search wasn't working. Google got me here thankfully.
The verdict is in.
The 65 battery fits and works fine in the main battery box. I did have to take a few swipes of the file on the fitting block but it works fine.
Will report back on the secondary battery tray soon.
Sent from my SM-N950U using Tapatalk
BG1988
you have the top posts correct?
petethepug
Michael
SoCal
I have a cheese *** undersized battery in our 09 Esky that’s throwing codes if left in accessory mode for more than a few minutes. Time to get another Bosch H7/L4/94R AGM like the Denali is fitted with.
BG1988
Your biggest issue will be how close the terminals are to the body brace above it. Grounding out the battery is bad...
H6 fits in the rigs i think some yukons have h7's
that is why you have a cover protector on it
petethepug
Michael
SoCal
Bosch Platinum Series AGM Battery Group, Size H7/L4/94R Typically $145 when on sale 25% off. Won’t crap out due to extreme hot/cold. Made by Exide in USA. Use them in all our cars now. Optima’s quality went down the toilet since Johnson Control purchased them and moved factory to Mexico.
Exide is no longer making Bosch AGM batteries or any that I can see. Pep Boys now sells Champion branded AGM made by Exide which now shows owned by .... wait for it .... Johnson Controls. They also sell a clone battery wrapped in AC Delco packaging with a smaller 3 year warranty and for $100 more. The Champion battery is still at a 4 year warranty exactly like the Bosch units.
Drewphil
