Skid Plates for our GMT900s?
Mine too but its cracked.
ya they made both plastic and aluminum ones, I had put the metal one on my 00 when I had it also. the metal are supposed to go on the z71 packages but my 18 Silverado z71 has a plastic one, apparently they only put the metal ones on the z71 suv's? so I found some new metal take off's from a Tahoe to put on it last night on ebay.
BG1988
there is also a factory metal one out there for the new z71 trucks but not sure if it would fit the gmt900's or not, I saw a picture of one on another forum
more then likely not
i can check the hybrid since it's lower it might have a "metal one"
randeez
south florida
I've been looking for some thing to put under the back of mine. Removing the spare tire it looks like the bumper would just act like a huge scoop at higher speeds. I figured I would probably have to make one starting with a wide rear diffuser for a hellcat or something. As flat as the rear bumper is a flat sheet of aluminum or abs could prob be used just to tie it all in and give it some support
you could mock something up with a big piece of cardboard and then use that as a frame to cut out some aluminum, might work for smoother air flow anyway
randeez
south florida
yea i mostly just want to add some support for the rear bumper in the middle but an entire pan shouldnt be hard to throw something together...its low enough it wouldnt really need to cosmetically be that nice. an angle at the front behind the rear axle a couple inches up as to not catch any air.
some 1/8" aluminum should be plenty? maybe find someone to add some ribbing to it if needed
ya sounds about right, just got to figure out a way to bend it, if you have a machine shop in town they can probably set you up once you have the measurements/angles needed.
Fischer
I have an 03 Z71 Suburban that is in brand new condition the way that they are I am certain that it has a full compliment of skid plates along with a trans cooler and the towing package! I love it
T
tgui
Thats the lower skid plate, not the main one. BUT I still got it cause I want it!
Just arrived:
b4I1oxglTXjKh9I-eHwMtKro6O3DzKwtMtylfVHY1P9rf78Ym1-O6VAmwYOXB0uOZsXhmAn-I4SWGLBwSPpz9NNNpx81_6eCl0vqVqL65NGTOlFJj0y-xeBlY1SKAfPQQ47QjrX-z0O7urvFF_0ikgkjCf8A_pZ2CQMJr8Yf7VqwPtqHIeBLZSlNvxRgVAl9yizu_MMz7ara67zrGbVV-y1rrMuZqkhrjCe9RrcXDKndzaEGbRPPuSUpWLlAACTEAFBpr4KxoKgy4TbGpj-8SfxRRSfGQ9rct7rFBfbQrrvbBAs6qHfEI32GzDyQAaiuHaEgWb-YS6ZjFEh4ynN2ylKtwKkH8CXcMNEf7EiALDTKo0ibs-RVAKnXZvLCGNn8jr0_CtPhrcGotWP6OptMKm77nrAtJ_HP1pdkWNUycQ4ikpRRNwmemcIouFpfNXqu_m84gdo54l1MiaYPL6aXfQCv1jA-aaB1foCBM6la-q2pdJtGYv1nLK1jw2HYrlgDxtjFKMwD-H5JXh-_D9Nr1SY9AXnQdbrsCzCspthBKfR0P5Qdy_M9Cq-GVhnR1xKDbHtTsUmHN6fAjkN-mRhubTnlVcarb0b9S4gI24UF-DLDOEKLPypoAffAa22P9bkZb0Fs5S045bza_NVVOB0_Exluqd3W06wQLP6Cm6CM4u6dNWPD5enG-bC8=w687-h915-no
Geoffsfas10
St. Louis
Got the front one installed, ordering the transfer case plate next.
Little tip for you guys, the OEM bolts are 6-11 bucks if you buy them new, and then gm parts direct charges 15 bucks to ship em!!! yikes. The OEM bolt is special in that its self tapping/cutting as you drive it into the holes. The bolt is also an M10x1.5x25. SO what I did was I went to O' Reilly's and got some yellow zinc 10.9 bolts in M10x1.5 and washers, I got 8 so i can do the other plate as well, and that was 13 bucks for it all. Since the holes arent thread to start with, I took out a bolt from the plate that was installed, and then I used that as my "tapp" for all the other holes. Just threaded it in til I guessed enough was through the frame thickness, backed it out and bolted in the other bolts. Worked great! All tightened down snug and the plate is in there.
St. Louis
Pics after they're installed is a board requirement!
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Geoffsfas10
St. Louis
2001 Yukon SLT
\When i get the t-case plate in I will take pictures. I still need to take formal pictures of my tahoe since ive bought it.
992dr
Eastern N.C.
I've always wondered if anyone made a metal front skid plate, now I know :)
Thanks for posting the links for the skid plate.
Has anyone tried to "make an offer" on his eBay link?
Pricing is fair but, shipping is rather steep.
The Whip
