01 Denali wiper issue
igell
so i've been having this issue for a while now..
1. when I press forward or use the window washer the wipers start working but do not turn off.
2. I need to use the wiper switch to turn wipers on/ then off - this does the trick to turn them off.
I did a little research and found that GMs have issues with wiper motor pulse board.. but my issue is slightly different so wandering if its the same fix.
I
igell
thats what i am thinking.. i think i can fix it myself by re-sautering the board.
GMT800 2005 Tahoe Z71
Navy Supporting Member
There used to be boards inside the the wiper motor cover that you could attempt to repair. This part is a whole module. Since I have not been in a shop for years I am unsure if you can solder the old board. I guess it is feasible so why not attempt it.
I
igell
i see what you mean.. they might have changes the design.. ill buy one, no biggie
The part I posted the thread for is the module but there may still be a board under the motor cover, if the cover is removable.
Brucecris
