01 Denali wiper issue
igell
so i've been having this issue for a while now..
1. when I press forward or use the window washer the wipers start working but do not turn off.
2. I need to use the wiper switch to turn wipers on/ then off - this does the trick to turn them off.
I did a little research and found that GMs have issues with wiper motor pulse board.. but my issue is slightly different so wandering if its the same fix.
I
igell
thats what i am thinking.. i think i can fix it myself by re-sautering the board.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
There used to be boards inside the the wiper motor cover that you could attempt to repair. This part is a whole module. Since I have not been in a shop for years I am unsure if you can solder the old board. I guess it is feasible so why not attempt it.
I
igell
i see what you mean.. they might have changes the design.. ill buy one, no biggie
OR VietVet
Willamette Valley
The part I posted the thread for is the module but there may still be a board under the motor cover, if the cover is removable.
X-ray Nerd
