Persistent Misfire cylinder 3
Nap73
What’s up guys
Need some help here
About 2 months ago I had a misfire in cylinder 3 with a flashing check engine light
I replaced the ignition coil and it immediately fixed the issue. I then went ahead and changed all the plugs and wires.
Now the 2 days ago about 45 min into an hour drive and I get another cylinder 3 misfire code P0353 solid check engine light and 2 pending codes P0303 & P0353. The mechanic cleared the codes and I went about my business.
Then yesterday I’m taking another hour plus drive and I get a flashing check engine light that stops about 3 mins after it starts. And I have 2 new pending codes P0303 & P0353. Light goes off and never comes back on. I clear the pending codes
I go to the mechanic today and he moves the coil from cylinder 3 (the one that was changed ) and exchanges it with the cylinder 1 coil. Now driving I get the same pending codes again P0303 & P0353.
What do you guys think ??
Any assistance or comments are appreciated.
wjburken
Eastern Iowa
What’s up guys
Need some help here
What is the condition of the harness going to the coil?
Nap73
Nap73
Might be worth the time to take a meter and check for resistance and continuity to rule that part of the equation out.
I’ll do that
Nap73
Nap73
Could also be an injector acting up.
You could swap the #3 injector around with the #1 injector and see if the issue persists.
That’s exactly what was done.
What’s up guys
Need some help here
Ok, With the coil swapped, the mechanic should have hooked up his bi-directional scan tool and verified that all ignition control circuits displayed OK. This means that there was no Short To Ground, Short To Open or Short To Volts.
If there is, fix the wiring. If all is ok with wiring, replace the ECM.
If the engine runs too long like this, it could take out the cats.
Nap73
Nap73
Everything looks fine with the scan tool. Before the ignition coil swap & after. And the misfire isn’t happening all the time. I ran a couple of 20oz bottles of Techron complete fuel system cleaner and took the truck on some longer rides. And it seems to be helping the situation as no codes or “pending” codes showed up until today. I’ll clear them and run some more of the cleaner thru the system. But to me it seems like an injector issue. Just out of curiosity why go straight to the ECM?
wjburken
Eastern Iowa
You said he swapped coils... you didn't mention he swapped fuel injectors too.
Did your mechanic swap the Coil or the Injector or both?
Because that's all that's left when you run through the shop manual. That P0353 is a specific code for a coil, not an injector or anything else. You eliminated the coil by swapping it and presumably the wiring has been thoroughly inspected and tested so all that's left is the ECM.
Watonga68
Mustang, Oklahoma
Mine ended up being a bad lifter in a 2016 Yukon XL with only 52K on it! P0307 in No. 7. Praying that is not your problem, as mine will be covered under the powertrain warranty.
Nap73
Nap73
Miss read your post Man
He swapped coils not injectors. Coils are an easy swap the injectors now that’s a different story. If I’m going that far I’ll just replace them all then.
Nap73
Nap73
Got your reasoning. So if it was an injector issue there would be a specific code ? Also I found a ECM for $220 on Amazon. How involved is this to instal ? I’m assuming a dealer needs to program or flash it for your specific vehicle. The explanation and info is appreciated.
I wouldn't jump to replacing the ecm unless all other parts checked first, the ecm is the last resort and yes it would need to be flashed. you would be better of investing the money in a tech2 then you can have dealer level diagnostics in your own hands and it would only cost you $40 to flash the ecm yourself if it came down to that, the tech2 will pay for it's self over time.
Nap73
Nap73
Ok so I ran 3 bottles of the Techron fuel system cleaner thru the truck one after another.
1st bottle in a tank less than 1/4 full.
2nd bottle on an almost empty tank that I then filled with 10 gallons of gas
3rd bottle on an almost empty tank that I filled with 10 gallons of gas
After the 3rd bottle I filled the tank.
I had to take an hour and 15 min drive yesterday. No check engine light. When I got to my destination there were 2 pending codes P0303 & P0353.
I then drove an hour and 1/2 home and when I arrived and checked the codes were gone.
Am I correct thinking that my issue is a fuel injector ?
wjburken
Eastern Iowa
P0353, as James stated, is a coil specific code. Your mechanic swapped coils and it stayed with #3. I think you stated that the mechanic even swapped injectors and it stayed with #3, but that wasn’t clear. I would make sure I have thoroughly checked the wiring harness going to your coils to make sure they don’t have any corrosion or possible loose connections or damage before going any further. If that checks out, then as the others have indicated, you will need to deal with your ECM.
Burby
Question - did the dealer go right to the lifter or was this found after doing multiple other diagnostics? How did they get to the lifter being the issue and how much did the diagnostics cost before finding the issue?
I've got a misfire on cyl 8. Tried sraying a can of seafoam into the intake and it only somewhat helped. 40K miles on a '16 Next step is taking it to the dealer.
enigmaspeed27
