Emmisions test required
corvette744
2004 Z-71
Northern illinois
So i got my notice on emission test due.I have my battery disconnected dont usually drive the hoe in the winter.I no that you need to relearn readiness monitors or you will fail.I dont know how many miles i need to drive before i can get a test done need to do it this week.Anyone have any info on the miles needed to relearn.
HiHoeSilver
Away!
Chicago
So i got my notice on emission test due.I have my battery disconnected dont usuall drive the how in the winter.I no that you need to relearn readiness monitors or you will fail.I dont know how many miles i need to drive before i can get a test done need to do it this week.Anyone have any info on the miles needed to relearn.
Better start driving it. It's not really miles, it's drive cycles, which can sometimes be harder to get completed. Do your best to vary your driving. There was a recent thread where he had driven a bunch and still couldn't get them to set.
Danny3737
Too bad you’re not in VA. We have something call RapidPass where they have portable sensing devices. You could have every dash light kit up and it would never know. All you have to do is go on their site and they will list the times and places they will be at. It’s always on a entrance or exit ramp.
they only give you a weeks notice? here in Commiefornia you get 90 days notice once every 2 years, then they just hook it to a computer and your done in 5 minutes.
petethepug
Michael
SoCal
The tech here in Cali recommend a mellow drive on the highway for 40-50 min at night w/ no traffic.
One or the other will give you better odds of jumping through all the hurdles.
It’s better to use a battery tender instead of disconnecting it, for both the battery and vehicle. Anyway, yes it’s drive cycles like mentioned and some of the sensors need specific speeds for specific times, etc. and it can be a real PIA. I gave up on one of my trucks and registered it out of the testing area after trying for weeks.
corvette744
corvette744
2004 Z-71
Northern illinois
Drove it 90 miles and went to auto zone and still had open cycles left.So yes its strange you need to have so many cold starts and varying speeds using cruise control and what not.I went to the chevy dealer to see my buddy used to work their.He hooked up the tech 2 and said you have only 1 light on that hasnt completed its cycle.He said your allowed 1 on go test you'll pass-he was right all done.So have to do this every 2 yrs.What is the battery tender device that lets you change battery without losing your ecm specs i cant find it.I disconnect my battery over winter so im not messing with bad battery in spring i dont use the tahoe over the winter.Winter up here chew vehicles up in no time.
The tender I use analyzes, cycles the battery by discharging and recharging, de-sulphates etc. You leave the battery connected to the vehicle. I learned about them from riding Harleys which are stored 6 months out of the year here and the batteries are a ***** to remove. I use one on my bagged truck because it sits for 4-5 months in winter. It’s better for the battery than disconnecting it and letting it sit plus all my settings and computers are kept up. I have a connector hard-wired in the truck and the tender just plugs in.
https://optimate1.com/om5vm/
BG1988
250 miles will do it still need one for the EVAP but i'm at 800miles so far still not ready on that one
Best idea would to put it on Non-Op if you don't drive it tell your ready DON"T try and smog it other wise you may get an Abort or Fail on the history... and will lower the resale value of it as it goes on the car fax
jeffbco
Google "battery tender" - you'll get lots of info.
Wes, that new pickup truck is looking better every day!
ya you know what's weird is that truck has all kinds of "not ready" emission's with 26k on it I have driven it a 1000 miles since I bought it and haven't disconnected the battery so I don't know what's up with that but it still doesn't have to have a smog inspection for 50 months.
jeffbco
Check to see if there are any old codes. Also, any random CEL's during that period? I think a CEL affects the monitors.
no codes, there were some historical codes the dealer was able to pull up "magically" as usual but no cel or anything unusual. I had them make me a copy I have to take my kids to school and then I will post them up I don't think they were emissions related though.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Mine only took a week of driving to reset and pass the test here in SE PA.
so on mine the old historical codes were p0097 iat sensor circuit low bank 1, p0113 iat sensor high bank 1, p2227 barometric pressure sensor "A" circuit range/performance, p2228 barometic pressure sensor "A" circuit low, p00f4 humidity sensor circuit low.
they all say test failed since code cleared, no cel. really weird codes.......
Wylie_Tahoe
C-Tek makes some great little chargers that you can mount under the hood and wire permanently to the battery to maintain the battery over your layup, leaving the battery connected.
Which of the emissions show as not ready?
AZPatriot1963
