NoReverseYukon
NE Wisconsin
Got the new wheel bearings on. Now, on to the next problem.
I have a rotational-based noise from the drivers front wheel well area. It was making the noise before changing bearings. It sounds like a plastic clicking noise which increases in frequency with vehicle speed. I don't see any obvious culprit.
Any suggestions as to what it might be ?
Also, how do I post a video/sound of this noise to help the forum in helping me to diagnose this ?
TheAutumnWind
Finally got around to replacing my drivers side wheel bearing. Wasn't making any noise or sloppy but figured it was time. Nearly 200k miles now.
Forgot my other pics
Edit: these are nnbs front brakes btw. 13" rotor 20" oem esky platinum rims
20191116_152613.jpg 20191116_160924.jpg 20191116_160409.jpg 20191116_160944.jpg
TheAutumnWind
I always get a couple people crying about paint on the rotors. It's gone after break in.
Yes my wheels are dirty... it's a kid hauler not a show truck. I'm lucky if it gets the softball field dust rinsed off of it twice a month lol.
Scottydoggs
NJ
could be a bad front axle, or the dust shield is rubbing the rotor maybe. ive had that happen to my car before.
i use you tube, then link the vid, or you could use fb and copy its url and paste it in the reply box here.
Sam Harris
Hey, they reflect well enough to tell me you have a hangnail on your left index toe.
CV joints typically make a clicking when worn. Worse when turning? Any difference with 4WD engaged?
NoReverseYukon
NE Wisconsin
While I was troubleshooting this, I removed the driveaxle on that side and went for a testdrive - the noise was still there.
I did notice a rip in the upper balljoint boot and a lack of grease inside.
I began removing the upper control arm but, of course, the balljoint stud decided it wanted to spin. Now I have to sawzall it off. I couldn't even get a visegrip to stop the spinning.
Well, damn. Maybe someone is pranking you with the ol' zip-tied driveshaft trick.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Drove it without a CV shaft? Did you have a spare splined hub to hold the wheel bearing together?
NoReverseYukon
NE Wisconsin
Man are those control arm bolts a ***** to remove !
I've been taking out my frustration on those mo-fos all damned day and still they remain, laughing at me.
ks03
Fool Excess Member
Nothing's gonna happen.
I think the O.E. ones are fine, but a few of the aftermarket that are 4wd specific will come apart without the axle nut on to hold it together. If it was going to fail, I think it would of happened by the time you made it around the block.
ASG-MikeS
