Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
yep, i have another one that looks exactly the same with just one in and one out holes. so i bought all 3/8npt to AN adapters. the one that i put in threads right in fine - the other doesn't :emotions122:
i tried about every fitting i have to thread into it, the only one that does is one to adapt from the side of the block to the turbo oil feed line on a stock block.
and for whatever reason i thought 90* boots to relocate spark plug wires would work, they dont so i have to order some more of those 135* probably
I need some real catch cans... these are a couple of cheapy ones off Amazon. I actually knocked the screen/filter out of the fresh air can it took a good amount of effort to blow thru. Just dont really feel like spending 400+ for a pair of mighty mouse or motion raceworks
View attachment 234082 View attachment 234083 View attachment 234084
I quit messing around and went with a dual inlet catchcan from Elite Engineering and added a Clean Side Separator. It was expensive though, around $400 for the catchcan with braided line and AN fittings and another $100 for the CSS. Very nice stuff though.
randeez
randeez
south florida
View attachment 234089 View attachment 234090
nice i'll take a look, i'll grab a nice one (or two given how i have it set up) at some point. im just trying to make it work with what i have at this point
randeez
randeez
south florida
Why not just a breather off each valve cover or some downdraft tubes?
breather would work most of the time under vac. on the 6.2 i had passenger side valve cover open to air - driver side ran to intake with check valve. underboost the passenger side would spit oil. this is sort of set up the same way with just much larger ports on either side so im assuming its going to want to spit oil out of the valve covers under WOT runs it will just have to run through a catch can before free air (the catch can that is mounted has little restriction as i removed the screen on it)
randeez
randeez
south florida
wired up the relocated flex fuel and fuel pressure sensors. fuel pressure sensor i was really hoping i could make an extension for it (because i just bought a new one, stock one is still in the stock line) but no luck. tight space so i didnt want to splice and extend so i thought i'll just pull it back thru the harness and if i jump it out of the main harness earlier itll reach. so after like an hour of pulling harness to the abs crap over the frame, removing all the tape and loom i get the pressure wiring back only to find out it goes towards the back of the truck (to the fpcm i imagine) so i have to splice it and extend it anyway.
soooo at this point I am waiting on correct plug wires to relocate coils, ignition coil extension harness, some fittings for the other catch can i have. i'll have to make up the spark plug wires but that shouldnt take to long
The problem with a single intake catchcan on a boosted engine is that on WOT it quits working when it’s needed most due to lack of vacuum. The one Im running has a second intake that’s connected to the CAI tube and both have check valves. That way , whichever has the most draw is the one that pulls air from the driver valve cover and it works under boost or vacuum. Then the Clean Side Separator acts like a catchcan on the passenger (clean) side but it operates at WOT only and when not under WOT it releases the caught oil back into the head so the vapor that’s drawn from that side doesn’t get oil vapors during hard throttle. Also useful for boosted engines. I believe your passenger side catchcan serves the same purpose?
randeez
randeez
south florida
How will you prime the oil system?
they (thompson) didnt seem to make a big deal out of it, they say just disconnect coils and injectors turn over a handful of times for about 10 seconds each and let er rip
sounds like it should work... cant really put the separator on oil fill location though. as it is i can hardly get the oil cap off lol
Oh yeah, it does add about 1 1/2”. Too bad.
I'm sure the assembly lube is sufficient. Mine often sits for 5+ days between starts and it has a lifter that drains down. I hold the pedal to the floor and hold the key to let it crank until the PCM stops it, wait a minute or so for the starter to cool a little, then crank again. When holding the pedal to the floor and holding the key, the PCM will let it crank for about 10 seconds even if you're still holding the key. I've noticed a few psi of oil pressure at the start of the second cranking cycle. That lifter ticks much more quietly and only for about 5 seconds when I do this. I'm sure I'm beating on the battery and starter, but I plan to tear it down for an AFM delete within the next couple of months.
On a fresh install, I disconnect the coils but leave the injectors connected and crank a few times to purge the fuel system. Of course, this is after purging from the Schrader valve on the rail. I just like to get the engine to start ASAP as if it's been there all along. Damned OCD.
Chert_Detective
So I found your build thread while looking for drag wheel/tire setups, ended up reading every page. I started first by thinking "Hell yeah he's already done everything I'm currently in the middle of!" Which then quickly turned in to "Noooo! He's doing everything I told myself I wouldn't!!"
Excellent to say the least. I'm in the middle of, what I told myself would be, a mild NA build on my 08' short body Denali. Front/rear 4.11s, Circle D 3200-3400, TSP 229/244 ls3 cam and vvt delete(thankfully being an '08 the AFM hardware wasn't even present), plus the usual LS valvetrain uprades except I'm reusing stock valves. That was all phase one of the build. Phase two entailed cnc ported stock heads, manifold swap, and flex fuel conversion. Two of the new lifters failed right off the bat so instead of pulling the heads to replace them, and then a third time for phase two, I just expedited phase two and am doing it all at once.
PS, your LSXcalade counter part is the welder at the shop doing the work. I just don't have the free time or space to do it at the house.
As you can see from the post count, I'm more of a reader, I was active as hell on the cobalt forums. I felt the need to post though and just say, badass man.
randeez
randeez
south florida
well, welcome! yea the cam/bolt ons was pretty reliable for over a year... i got it to where goal was running on just motor and was time to do more. plan was just to turbo and enjoy for a while and same crap had a few mishaps and jumped a few steps lol. at the time i sized injectors to be able to cover how much the 80/96 turbo could flow - so upgrading to bigger turbo means new injectors prob more pump, new intercooler, etc, etc. and then it gets into if im going to make that big of a jump i should put the money into a gt55 and just need to call it quits. but i will see how much this engine gobbles up the turbo i have, if im not out of injector i will probably just grab next size up that fits right in place and not have to change any hot/charge pipes.
LSXcalade - i didnt come across his build until about 4 months ago when it started popping up on IG, probably would have saved me a lot of time with some things, i took a lot of cues from Three6GMC on PT/FB/IG with a gmt900 (truck but pretty much same platform)
Chert_Detective
His issue right now I believe is yokes and u joints. Drives it all the time though, it's pretty badass.
I'm just going to stick to a nice flex fuel build though. Heads, cam, manifold, converter, gears. If it needs a little bump to hit a 12.99 I might put a small plate kit on it. I'm using a 450 intank with the stock hat/regulator and FAST 50lb'ers. Should be enough for what I need even if I have a higher ethanol content in the tank.
Onebad1983
Resident Country Dumbass
You're talking about Stapleton42 right?
randeez
randeez
south florida
Yea I dont think theres going to be anyway to avoid breaking those, I havent had any problems with driveshaft (yet) but being shorty and having true awd transfercase(ie front wheels not locked with rear wheels) I'm hoping will help. Its almost like leaving them sacrificial is better imo than breaking the trans every couple months
JasonW4141
