Rim Choices 2007 GMC Yukon 2500
Nap73
What’s up guys
Thinking about getting some new shoes for the chariot. Need some opinions
2007 GMC Yukon XL 2500 stock suspension. Would level if I absolutely had to but would rather not.
I’d like to get some larger more aggressive looking AT tires so take that into consideration.
Appreciated any input
Matt_
With careful trimming I fit 305/60/18 stock, wheels were 9" wide +18mm offset.
I don't have the 2500 truck, but on my standard 07 XL Denali, I am running 305/50x20 tires (not LT tires) on stock rims with no rubbing.
avalonandl
Troy, MICH & Naples, FL
Keeping stock wheels ? they are 6.5 wide so limited tire choices 265 MAX!!!
8 lugs and LT Tires are a must.
Michelin Defenders....
Nap73
Nap73
Don’t want to because the aren’t wide enough.
Matt_
Got any pics ?
For some reason I'm missing most pics on my phone. There are a bunch in my build thread, of the trimming as well.
Nap73
Nap73
Brother that’s the look I like. Truck looks mean AF. How’s the width ?
Nap73
Nap73
Let me see a pic
ivin74
05 NBS Nali
Htown, Texas
I've seen 2500s withh305's on stock wheels and a 2" lift in the past. They look good.
Nap73
Nap73
Came out perfect IMO. Right at the edge of the fenders
That’s pretty much the look I’m going for. I looked in your build thread and you described the trimming but I didn’t see any pics. How involved/extensive was the trim?
Matt_
Front bumper supports cut, then reshape the liner with a heat gun, zip tie to hold it back
Pic of passenger side
Pic of driver side complete
Norcal fender mod for the firewall side of the wheel well
Self tapper to hold the liner back
wilcfr
Hope you don't get much snow or slush in your neck of the woods. It would take much to booger up you turning radius with that little clearance.
Matt_
Clearance is not any different than stock. Add bigger tires, trim and reshape liners to get clearance back. Stock tires damn near touch the liners at full lock.
It's a complete non issue. I love the snow
Nap73
Nap73
Only issue is I’m not really looking to cut up my truck. I’d trim some plastic but definitely no and metal.What’s the biggest I could fit without all the metal trimming ?
Matt_
It's not hard to do and isn't visible once the liner is on. You basically make one "cut", then fold the two flaps of metal up onto the firewall. No structural or cosmetic changes. I smooth all edges and put a few layers of oil based epoxy for protection. Have done this on every GM truck I've had.
Bwaldron
