Changed my overflow tank cap today. Old o-ring looked shrunken compared to new. Seemed like it would hold if I cranked it down really tight, but when I pressure tested the cap it leaked unless I really tightened it up. $7 so new it was
You just made a bunch of people check their overflow caps.
SRQYukon
Sarasota, FL
Finally got my damaged chrome bumper replaced with the painted one. Sprayed it Dark Spiral Gray like the body. Trying to decide if the final chrome piece (the grille) needs to go dark.
Fosscore
Finally got my damaged chrome bumper replaced with the painted one. Sprayed it Dark Spiral Gray like the body. Trying to decide if the final chrome piece (the grille) needs to go dark.View attachment 233386
Color match it.
Go look at these 2 Denalis.
@adventurenali92
And
@Rocket Man
For more great ideas. And $$ to spend. Cough cough ..
lol had this ready to send and forgot to post.
Sam Harris
I think it looks good as-is. But looks like you don’t have much chrome anywhere else... hard to tell from the one pic, but if not.. definitely need to do something with the grille as well.
SRQYukon
Sarasota, FL
Yeah, no chrome anywhere else except grille. Looks like the color matchers have it. That's the way I was leaning anyway. I even have enough paint and clear leftover to do it. Think I'll buy a fresh non-chromed grille shroud and spray it. The plasti-chrome is starting to peel on my original one.
Great idea. I tried like hell to find one for a Denali but nobody makes one. It sure would have made it easier.
BG1988
Still stressing about the used oil analysis tests showing coolant in my oil. I have also noticed signs of coolant or moisture on the bottom of my oil fill cap, but NOWHERE else. But two tests two YEARS apart showing coolant in my oil? WTF is going on? Could it be such a small amount of coolant that it doesn't quite get a chance to do any harm because I change my oil regularly? Because of that, plus the fact that it's my daily, I'm still driving it. I just hope nothing bad happens before I get the chance to investigate it further. I'm off half a day on Saturday, so I'm planning on taking the valve covers off to see if I see any signs of milkshake oil. Truck still runs perfectly fine, doesn't run hot at all, and the oil "appears" to have absolutely no coolant in it on the dipstick and when I drained it from the oil pan. I guess I need to double check and make sure I don't have the dreaded Castech heads. I could have sworn I checked for that a few years ago when I last replaced the valve cover gaskets. That was around 2012 I believe.
just don't use any sealant with sodium silicate aka water glass
ScottyBoy
Shreveport, La
If never add any shit like that to my coolant. Lol
But a small update, I did take the valve covers off to inspect the heads. ZERO signs of coolant on either of the heads. No milkshake, no peanut butter, and no areas that were abnormallly clean or shiny. The ONLY sign of coolant or moisture was on the bottom of the oil fill cap. I'm starting to wonder if my oil got contaminated a while back when the plastic "T" at the heater core broke and sprayed coolant EVERYWHERE in my engine compartment. I've only changed my oil twice since then, and although it's far less,it's still showing trace amounts of coolant. I'm going to inspect the cylinders next as soon as the borescope camera comes in that I ordered off eBay. And I'm going to send in another oil sample after that, regardless of how many miles. I only have about 800 miles on this oil so far.
My lower intake gasket (the plate with the knock sensors) is leaking, so it's QUITE possible that coolant seeped in through that gasket when the T fitting exploded. But I still won't feel comfortable until I inspect each cylinder, and get a few more oil analysis tests done.
NjA4207
