ladorn45
The list is right there, I listed them all. Inner and outer tie rods (4pcs), upper control arms which include upper ball joints (2pcs), lower ball joints (2 pcs), pitman arm (1piece), idler arm (1piece), idler arm bracket (1piece). I don’t think I’m forgetting anything. Your part numbers will probably be different than my 02 Denali.
Awesome adding how many pieces is super helpful. THank you. I never done suspension before so slowly learning what that includes. Now I just gotta hit up youtube and see how easy they make it look lol.
I finished painting my door handles and speaker grills and reinstalling the carpet on my door panels. Door refurb complete.
Fosscore
Just ordered the Moog Problem Solver inner and outer tie rods for the Tahoe.
Moog ES3488 Inner Tie Rod End Problem Solver
https://www.amazon.com/gp/product/B000C57W7C/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Moog ES3493T Outer Tie Rod End Problem Solver
https://www.amazon.com/gp/product/B000C59WHA/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
Used a 5% discount code and PayPal balance and even with shipping, this round they were the cheapest.
That is almost $100 cheaper than at Adv Auto and Pep Boys, even with their 25% discounts!!
Sam Harris
Thx Sam. Whenever I get motivated enough I'd like mine to sound more like yours. Mine has gotten louder since its burned in. You know what they say--If it's too loud, you're too old! Lol
But you have a cammed 6.0... it better be louder! [emoji16][emoji631]
ScottyBoy
Shreveport, La
Just got my used oil analysis results back. Now I am concerned because they are saying that I have coolant in my oil. I do acknowledge a coolant leak, I have to add almost a quart probably around every 8-10 months or so. But it's definitely not enough that I see any discoloration or anything in my oil. No "visible" signs of coolant in the oil. And no, I don't have the dreaded Castech heads.
ScottyBoy
Shreveport, La
That says your sample from 2017 was worse in all areas though. Is that historical comment from sample 1 from 2017 or the current sample, #2? How many miles on the engine? 148,000? It says 14 in 2017...
Not sure why it says 14 miles on it for 2017. I believe it had about 140k on it or so. Maybe they forgot a few zeros on there, lol. But yes, my last sample was indeed much worse. I just chalked it up to going SO long on the oil, because I went over 10k miles on it. The next one I only went about 5k, but I forgot to do a sample. Now I'm at 148k and just changed it and sent in another sample. It makes sense that all the wear metals are down, but there's still what they call critical levels of coolant in the oil. The ONLY visual sign of coolant I have EVER seen in my oil was moisture on the bottom of my oil fill cap. And I was told that is normal with my driving style, I very rarely drive more than 4-5 miles at a time, then the truck sits for at least 6-8 hours.
HiHoeSilver
Away!
Chicago
Here's a screenshot of my oil sample results. View attachment 232591
Your wear numbers have certainly improved. Says a lot for a shorter OCI, imo.
Your sodium and potassium are REALLY high. After ~6k miles, mine were 8 and 2, respectively. You have coolant in there somehow. Your intervals are very long, so it's tough to guess how bad it is. A little leak adds up over such a long OCI.
briannorris
