2014 SSV has cruise control but doesn’t work
5strmtrp
2014 SSV, the crummy steering wheel on my truck has the Cruise control set up, and to the best of my knowledge is the original wheel from factory.
I Tried using it this past Friday and it doesn’t work.
Is this something that needs to be connected? Programmed or I just have to start poking around.
I do want to get the leather wheel with cruise and radio functions but currently putting my funds into other needed things on the truck.
cruise would be nice with this wheel for now.
thx
Paul
Wolfbraid
Winston Salem, NC
My cruise control went out when my brake switch(on the pedal) was bad. Replaced the switch and all was good.
I believe it was throwing a code, but no check engine light shows. so if you are able to pull codes(most parts stores can pull them if you need)
Any problem with brake lights, brake switch, or led tail lights without a load resistor will disable the cruise.
mattjones
VA
Seconding this, had the same issue with my last Tahoe. Pressing the brake pedal deactivates the cruise, so when that switch in the pedal goes out you can’t use the cruise. It’s an $8 part that only requires 10 minutes to replace:
https://www.amazon.com/ACDelco-D1539J-Original-Equipment-Switch/dp/B001KSGJKQ
I’m pretty sure there are tutorials on this forum if you search.
5strmtrp
5strmtrp
I just double checked to make sure but All brake lights work fine, including Hazzard’s (4ways), turn signals.
I did have to silicone my rubber grommet that the 3rd brake light harness goes thru into the truck last week as the plastic piece was cracked under the rubber piece and water was leaking into the back of the truck.
Hmmm
Paul
5strmtrp
5strmtrp
On some of the SSV the cruise controls were not activated for some odd reasons.
Do you know if it’s just a simple connection either at the steering wheel or further under the dash?
Thanks
Paul
Wolfbraid
Winston Salem, NC
Hmmm
Paul
all my lights worked fine as well,
I got to thinking, I'd make sure that it actually came with cruise control, and someone didn't just swap a steering wheel.
someone here will know how to run the RPO codes in the glove box.
balln2k11
Likely its the brake light switch. Had the same issue where all lights worked fine and no check engine light, but did see the code for the brake light switch when using my scanner.View attachment 232620
balln2k11
5strmtrp
5strmtrp
Thanks for the info, what did you have to do to get it to work? Clear the codes obviously won’t do it, bcm flash? Replace the brake light switch?
I don’t use it all that often as my commute is usually in moderate daily traffic. But longer trips it comes in handy.
Paul
balln2k11
Dang sorry for the delay. Replaced the brake light switch (which is easy and horrible at the same time), this allowed me to use Cruze controls again
jmm121783
Searching for the next sunset...
Detroit
I noticed that just one of the wires on the harness to my brake light switch was frayed and not "connecting" with the connector inside of the brake light switch. I cut, stripped and inserted the bare wire back into the harness and it works great now. I still haven't soldered it LOL, I need to do that!!
5strmtrp
5strmtrp
Thanks for replying, been stupid busy @ work anyway this is the 1st chance I’ve gotten a chance to look here as well.
General Fodder
