Which Wires??
hornsfan44
GA
Which wires go to the Sub? I cant see under to the sub. If someone knows, I can use those and hook up my Line out Converter. Also, do I need to solder the connections or can I just use some quick connects? Again, its a '03 Yukon w/Bose. Hes a pic i just took after pulling the cupholders.
puckhead
CO
Soldering it always better but you can use quick connects. I havent had problems with them. Some have. I usually splice and use heat shrink. Dont know which wire it is though, sorry.
H
hornsfan44
GA
Thanks for the tip. I have both and just had the wife pick up some more solder for me.
Tahoewhat
Ballin' on a Budget
TX
Just had mine done, my tahoe isnt here at the moment, for me to double check, but i believe they are the blue wires, lt and dark blue.... but again i need to double check...
groundscr8pr
flaccid member
scarborough maine
i dont get the wires in that connector. get them at a 4 pin plug on top of the factory sub box.
Read numbers from pin side of vehicle connector.
FUNCTION PIN WIRE COLOR
R/R Pillar Tweeter + 1 WT
R/R Pillar Tweeter - 2 YW
L/R Door Spkr + 3 BN
L/R Door Spkr - 4 YW
Left Front Spkrs + 5 TN ¹
Left Front Spkrs - 6 GY ¹
R/R Door Spkr + 7 D.BU
R/R Door Spkr - 8 L.BU
Right Front Spkrs + 9 L.GN ¹
Right Front Spkrs - 10 D.GN ¹
Noise Mic Signal 13 D.GN
Noise Mic Drain 14 L.GN/BK
Right - Input 15 OG/BK
Left - Input 16 D.GN
Left + Input 17 TN
Right + Input 18 L.GN
Audio Shield 19 BARE
Data Line 22 D.BU
Constant 12 Volt 25 OG
Right Subwoofer - 26 L.BU/BK ²
L/R Pillar Tweeter - 27 VT
Left Subwoofer + 28 D.BU/WT ²
Chassis Ground 29 BK/WT
Right Subwoofer + 30 D.GN ²
L/R Pillar Tweeter + 31 RD
Left Subwoofer - 32 L.GN/BK ²
¹ The front tweeters are wired in parallel with the front door woofers.
² GM labels these outputs as "Left" and "Right" but there is actually just one forward-firing DVC sub in the system. It is mounted in the front of the center console. The Bose amp is located below the center console. To access either unit, the entire center console must be removed from the vehicle.
H
hornsfan44
GA
So the sub is waaay back there. So there is a 4 pin plug there? I'll dig and find it. Thanks
Im guessing that after I tap into those, I connect those to the A5, 6, 7, and 8 on my Scosche LOC? (says those are the REAR L and R pos/neg) -- or does it matter which side?
Also, where has been the easiest spot to tap the Amp Remote wire to for you guys?
H
hornsfan44
GA
Am I going to have to pull the complete console out to get that connector or is there an easier way to access it?
Anyone know where a connection is nearby to connect my Amp remote wire or should I just head to a fuse box?
vsaravia
