LED Brake Light Repair
AzCoronaDog
Arizona
I just bought a 2017 Yukon XL Denali and I discovered the passenger side brake light was not working. (Shame on the dealer for not catching this!)
What would have been a $2 bulb on my 1990 Suburban is a $500+ assembly on this one!
So, Google being my best friend, I discovered this is a common problem for this model series. A manufacturing defect in my opinion, but GM will never admit that.
I also discovered you can fix it yourself pretty easily, or at least try before you shell out the big bucks.
I found a good YouTube video (after I did it the harder way carefully removing the lens... LOL), titled "2016 GMC Yukon LED Brake Light Repair"
Here is the link:
Be sure to watch it all the way through, the guy realized he should have been neater about sealing the holes.
Miami-Dade
Moderator Supporting Member
Here is the link:
Thank you for posting all that information Jeff!
BG1988
Remember do it in a well ventilated area don't want to breath in the plastic fumes
also that soldering is total armature slightly incorrect
as he is going to be doing that job again in the future
you will need like some flexible wire ( not a solid core wire )
also soldering FLUX
good leaded solder
Rygrego
Topock, Arizona
Update as of 2020: These tail lights are now covered under a warranty extension for 6 years or 72,000 miles through the dealers. I just had my 2016 tail lights replaced for free at 64,000 miles. Saved over a $1000.
BG1988
Here is the link:
i though about upgrading mine with 35 watt leds headlights
a dremel would be better to open it instead a iron i would use 3d printer plastic to seal it back up with an soldering iron.....
Rygrego
Topock, Arizona
And a Dremel cut open tail light is better than a free new tail light?
trailblazer
Just did this tonight. I pulled the drivers side unit and it appears to have already have had a repair that failed. Seems like you have to either jump it with a wire or use a much more rigid jumper than just soldering the cracks. I suppose globbing the hell out if it with solder would work.
I used a dremel tool with a grinding burr. This was 100x easier than a “hot knife”.
trailblazer
I should note that I covered the exposed area with black electrical tape before globbing it with Dynaflex sealant (auto parts store had just closed and I didn’t want to dig out the RTV).
BG1988
Yes i was thinking a Hot glue gun could be used to insert 3d printer plastic to melt it instead of a soldering iron... i think 30watt would do the trick(outside of course )
I see not many have seen the wonders of a plastic welder, albeit the good one's are a little pricey
trailblazer
I was worried about this failing again that’s why I covered the repair with a small piece of electrical tape and globbed Dynaflex sealant over it. Definitely waterproof and able to handle four seasons. Plus I can scrap it off if I run into issues again (like me repairing this repair). Seems like the best repair would be to either use a humongous glob of solder or preferably a small copper wire so it can handle the flex that is going on in there. What a weird design.
justinb181
I'll be tackling this soon, what grinding burr did you use? I was thinking about using a cutting wheel but worried it may cut too deep.
trailblazer
I had a carbide one laying in my toolbox and used that one with my Dremel. It is cone shaped. Just take your time and have a firm grip on the tool and light fixture.
BlaineBug
Clown World
If you're in there you may as well do both. Solder to bridge the gap and restore the structural integrity of the metal, but then add a secondary "fail safe" flexible copper wire for good measure too. Fix one cry once?
CKendrick
