Show off your 2015-2020 lowered tahoes and yukons
16SLE91
what is the space between tire and fender in the front and the back?
4” in the front and 3” in the back difference with the back being lower. It actually is about 4” in difference because I have about large subwoofer setup.
Balistikb
I think I might want to raise my car by 1” in the front and back. Not sure if I totally like it this low.
Dearmosd
They rub at full lock on the mud flap
My RST Suburban also rubs when in full turn left or right. I just switched to michelins tires and dont recall hearing it (just got them yesterday) but with the stock Bridgestone's I heard it. It was very slight touch but enough to be heard. I couldnt figure out a way to avoid it.
Akinshake
Bowling Green, KY
NorCal leveling kit. Adjusted to about 3/4” rake
LTRAutomotiveRST
After some more miles the factory bridgestine's are rubbing on the sway bar both sides.
Dearmosd
I will have to check that. I just stuck my hand around the tire when it was on the ground and just felt the fender wall plastic. I will have to raise vehicle and get a better look at what all its touching.
I also have a odd sound from my rear after spring change. I need to raise the vehicle uninstall the kit and reinstall and double check everything but it sounds like the noise sounds like the springs squeaking when hitting bumps, annoying and makes me feel like I have a cheap vehicle with the sounds. Same as the front rubbing when people hear it makes me feel like they are thinking there is something wrong or cheap product or install
Andy Schmidt
NorCal 2-4 drop. 24” Status Juggernauts. 285/45 falkens. Rides like a dream. Although, the rear is kind of soft being is I got the mag/auto ride rear kit, which has different spring rates as apposed to the non-mag spring kit. Will get some helper bags to stiffen it up a little
534817C3-CE33-4B3F-A995-BD98A9C09162.jpeg D1B7C154-18AF-4EB7-A1D1-BA0CE8828379.jpeg
Dearmosd
Here is some findings from my front rubbing. With new tires I did full lock to lock and only found rubbing inner fender but at some point I see some rubbing on sway bar
Nocal, is this normal for vehicles with stock 22" wheels?
olyelr
Elk Rapids, MI
View attachment 230329 View attachment 230330 View attachment 230331
Just pull the liner back a bit with a zipstrip. The rub on the sway bar shouldnt cause much of an issue. Rarely will hit it, and probably dosnt make a sound.
Dearmosd
the part of the fender liner is pressed right against the interior cabin liner so maybe banging the liner might be minimal but enough then there is really not a place to zip tie but....I will have to experiment.
mb1500
Used to “NorCal Nick” the fenders on NNBS trucks, not sure if you can use it on these new gen.
You can pick up 1/4” wheel spacers at the auto part stores for cheap. Hardly noticeable and will take the tire off the sway bar.
FWIW I’ve got sway bar rubbing on my stock 16.
Brian Parsells
Hi all, first time post but was able to get a bunch of good ideas from this site so thought I would share pics of my 2016 Suburban LT 4x4. I lowered the rear 2" with the Norcal SS kit (front is stock) and added 22" Dub Shot Calla wheels and Yokohama Parada Spec-X 285/45 r22 tires. Also tinted the front windows and added black chevy bow ties.
The rear still has approximately 1/4 rake after it settled.
Brian
Dearmosd
Yep, I was pulling into a parking area and at full turn going over a curb the sound coming from the front end was bad. Bad enough my passengers quickly asked what was wrong....I was embarrassed to tell them that it was normal. I really feel like swapping to the stock spindle and change over to the coil overs and try to eliminate all factors involved with rubbing and retain the lower ride height.
Anyone have part # for Belltech coil overs?
CMoore711
Why is it that you think it's the drop spindles causing your wheel rubbing issues? If you re-installed the stock spindles and then lowered the vehicle with Belltech coilovers (or springs, or lowering "cups/rings") to the same static drop you have now the problem would still exist. The spindles aren't causing your wheels to rub, your ride height is.
If you want to have your truck lowered at the height you're at now and run the same size wheel and tire without any rubbing I would suggest you look into the "Norcal Fender Mod". There are many online videos and how to of shops doing this mod to both raised and lowered trucks in order to gain clearance in the front wheel wells.
LTRAutomotiveRST
The other thing I have noticed is that these spindles give a touch of positive camber over the stock ones. They are still with in the factory spec but I think I am going to try to adjust them out just a touch. I'm not rubbing at all on the fender liners but I need tires.
Dearmosd
If the rubbing is in the rear of the wheel well then how could a 1.5" drop effect that area of space. I could easily see if it upper fender well was effected. The rubbing i see on the fender well might be in an area might be grooved in such a specific are that the tolerance is so close were maybe the drop just eliminated the tolerance.
Norcal suggested a 2x4 trick to push back the fender well lining so I will try that tomorrow.
Plus Im not a huge fan of the MRC suspension so maybe I was looking for an excuse to get the coil over option.
Phildirt
I read all 24 pages of this thread - - - so pardon the question if I missed something.
New to the late model/lowering thing. I just upgraded from an 05 Suburban to an 18 Tahoe LT. It is 4wd with the premium ride suspension (not auto ride, it has the Nivomat shocks). I'm looking to lower the rear 2". All of the Max Trac applications I saw on their site are for auto ride so I looked at Mcgaughy. They do have 2" springs for the rear but there's a note that it is for 2" diameter shocks, not the heavy duty ones - meaning I'd have to buy those and ditch the Nivomats? Any feedback on the quality of that setup or would I be better off going in another direction? Last question - if I went with their springs/shocks would I'm assuming I wouldn't need the relocators, correct?
Not looking for a 2/4 or anything, just want to level. And I don't want it to ride rougher. No plans to tow anything.
Thanks
eand28
Pennsylvania
Thanks
https://store.tbssowners.com/index.php?act=viewProd&productId=578
That is probably what you're looking for
Dearmosd
It says it's for autoride equipped
edit - I kept reading lol
2.5 is a little lower than I want. I'll call him
Call, I know there are spacers and other little tricks to help fine tune the height you are desiring. Also don't let the #'s fool you. I didn't think I wanted 2" but it isn't that drastic if you ask me. I wanted 2" but feel the 2.5" was better. 3" wouldn't work with the lack of drop I saw on my front end so....2.5" was more ideal
ScottS-Michigan
