Headlights. No high beams
Sofi09
Ok so my high beams stop working. I checked and replaced both high beams but still nothing The high beam indicator comes on when it’s supposed too. I have head that the wig wag module could have gone bad even though it’s not operational. Where is the wig wag module how do I replace it or by pass it?
Sofi09
Sofi09
No, the wig wag module is between the rt front fender, ( liner, turtle, apron) and the front bumper. you can see it barely if you stick your head in the right place.
Stick my head where? [emoji23]
Does anyone know what it looks like ?
take a couple screws out of the passenger side front splash guard between the front wheel and the back of the bumper they should be 7 or 8 mm when you have a couple out you can pull it back and look inside with a flashlight. basically behind the front right headlight.
should be a black module with wires, could be aluminum also depending on the module, should look something like this
Kee Fuller
las vegas
wonder how much this sells for. I'll take a look and see if mines is still there
that one was for a Impalla, but there not all that much just depends on the name I guess a few different company's make them and a bunch of china brands out there also.
Sofi09
Sofi09
I just got in from the garage. Hi beams are fixed. Fuse compartment was disgustingly filthy and the fuses were loose. Simple easy fix. Thanks guys!!!
X-ray Nerd
