avalonandl
Wes, is your engine modified? You need to see a tuner to cut back on the fuel. Your dumping fuel into your engine. Check a plug for color.
no mods other than a cai and ls7 throttle body, how could it be dumping fuel the short terms are -2/0 the long terms are 7, checked a couple plugs a couple weeks ago they looked fine, i didnt check them all, would a leak down test show anything?Wes, is your engine modified? You need to see a tuner to cut back on the fuel. Your dumping fuel into your engine. Check a plug for color.
Turning up the boost? What PSI and HP/TQ you at now?
pretty much since I have owned the truck about 2 1/2 yearsI think the MAF thinks your flowing a lot more air.
You should be pig rich....
A CAI can do that. How long has it been installed?
had 2 new magnaflows put on it today, the last couple times I looked the long terms were at 7 both times, it's weird that as soon as the p0430 code cropped up the mileage went up from 8 to 9.5, I can take a look at it some more tomorrow with the tech2Late to the party, but I wonder what Wes, took out the cat? Sticky fuel injector? You can turn them on and off and check your fuel pump trims too. Your LTFTs @ 7, if they stay there for a long time are off. What's your alcohol content? If that number is off, you can reset the Fuel Trims and Fuel Composition and start her over again.
My last two fill-ups have been with 93 octane (due to low prices) and my alcohol % on this current tank is 0.0Late to the party, but I wonder what Wes, took out the cat? Sticky fuel injector? You can turn them on and off and check your fuel pump trims too. Your LTFTs @ 7, if they stay there for a long time are off. What's your alcohol content? If that number is off, you can reset the Fuel Trims and Fuel Composition and start her over again.
Just because , it's never been a problemWes, why do you have an LS7 TB on your engine...?
I don't think the fuel trims are stuck, I think what I was seeing was the data display showing 7 until it starts receiving data, the long terms are around 5 which should be good as far I am able to determine so farhad 2 new magnaflows put on it today, the last couple times I looked the long terms were at 7 both times, it's weird that as soon as the p0430 code cropped up the mileage went up from 8 to 9.5, I can take a look at it some more tomorrow with the tech2
I guess the real reason is eventually I would like to upgrade stuff a bit, maybe port the intake and install a better cam, the engine is still under warranty till March of next year so I haven't really messed with it yet and I don't have a *** of cash to throw at it all at once so I have to do it a little at a timeWes, why do you have an LS7 TB on your engine...?
The throttle body doesn't void the warranty?Just because , it's never been a problem
