jlee
- Joined
- May 25, 2015
- Posts
- 24
- Reaction score
- 18
My 09 5.3L non-K5L with 161k recently had the following work done at a shop:
New Delco trans cooling lines as old were leaking
Added stock K5L oil cooler as we are planning on getting a boat and I was already changing lines
Delco trans fluid change and delco filter change (no flush) as it was last done around 75k.
My first longer trip on a warm day was my trip back from zoo with the family and trans temps kept climbing on way home. It hit 250 as I rolled into the driveway which I know is way too high. Last 15 minutes of the 45 minute drive was over 220. I checked the added cooler right after we got home and it was cool to touch (same as ambient according to IR gun) along with lines to / from the added cooler suggesting trans fluid wasn't flowing through the radiator / cooler. No leaks anywhere. Checked fluid and it seemed a little over HOT, but it's hard to tell with the clean fluid. Checked fluid level this morning after sitting overnight and it was between the cold and hot range idling, but I didn't shift between gears before checking. Coolant temp never went above the normal 210, so I don't suspect any kind of radiator / fan issues. Before the above work, I usually hit max of 195 or so on a 90+ day like yesterday. Never noticed any odd trans shifts/slips or temp warning from the truck on our trip home.
As I understand it, there's no air purge procedure for the cooling lines / coolers, right? Also, there shouldn't be any check valves in the system that if lines were swapped would block of flow, right? Could high trans fluid level prevent fluid from flowing through radiator / cooler? Once we get it fixed, should I have fluid changed out once again to be safe? Anything else trans related I should have looked at after these temps?
I'm probably taking it back to the shop that did the work on Monday, just looking for some possible explanations to what's going on here and whether or not I should get the fluid changed out again to be safe.
