Jump seat mount
Sofi09
Hey guys I just picked up this center jump seat but I don’t have the mounting bracket. It’s for my 09 PPV
Any suggestions ??
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
The bracket is part of the bottom jump seat. all you need to do is remove both driver/passenger side seats and place in the jump seat then put back driver/passenger seats bolt them down and your done.
What he said. ^^^^^^
tfi racing
Yep, it's that simple as the others have posted,all you need is right there. Now would be a great time to clean out the french fries,pens,small change and that icky, gooey substance that always seem to be under the front seats...
iLikeEggs
Potato!
Oregon, USA
Hopefully you got this in already. If not, you can get the star sockets for the bolts at Harbor Freight pretty cheap. Front and rear bolts are different sizes. You can also use metric sockets. The whole job doesn't take long.
Just use 12 point sockets. Problem solved.
Sofi09
Sofi09
I didn’t get it in yet. It’s been at the body shop feeling the rust off the tailgate and pass rear wheel well
I’ll post pictures when I get it back and the bottom of the console is
Thanks guys
Sofi09
Sofi09
Ok so I finally got the truck back from the body shop. Here is pictures of the console
It looks like there are bolts on the bottom to attach to some bracket
Isn’t that a jump seat that’s already in there?
Sofi09
Sofi09
It’s just sitting where the police console was it’s not bolted down
Ok...but the first post shows a black jump seat, but then this pic shows a grey jump seat that matches your interior. Which one do you have, because the black one has the normal mounting brackets that attach at the seat bolts.
Sofi09
Sofi09
I have the last picture Of my actual interior The generic pic from the beginning was incorrect
Oh ok. We need to see the actual jump seat turned upside down so the brackets (or lack of) are visible.
Sofi09
Sofi09
Will do I’m working overnight tonight I’ll try and take in am.
Thank you
Kee Fuller
las vegas
Looks like you have the jumpseat off the 15+ Tahoe. Mine looked like the first pic you posted from ebay. Thats probably why its not bolting up correctly
Sofi09
Sofi09
If it is the 15+ model jumpseat any suggestions ?
Kee Fuller
las vegas
I dont think the brackets are removable on yhe nnbs jumpseat..when i sold mine last year it was a pain to ship it via fedex cause i couldnt find a big enough box to ship it. Ended up cutting a box down to make it fit with the bracket sticking out
Ilikemtb999
Denver
My 2010 had a 2015+ for a while. Some bent sheet metal to mimic the 07-14 style welded to it worked like a charm.
Unfortunately this is the only picture I have of it.
Ilikemtb999
Denver
If you hunt around you can find deals on full consoles. Much more user friendly. The 2015+ jumper couldn’t be used as a seat and the arm rest always felt in the way of the hvac.
My wife likes this far better
HeavyHoe03
