Tylus
South GA
I wrapped it all on the truck. It might be more effort than it’s worth to take it off. The bottom window trim will not benefit being off since where the chrome meets the rubber trim are not separate pieces.
Are you going to lose your side blind zone alert?
Even though mine is an LT, it was weirdly optioned. I didn’t have turn signal mirrors or the side alerts
But I do have the upgraded audio system, and the host of sonar stuff and lane maintenance stuff
humer101
NJ,USA
How you going to upgrade the Radar with the option when these options are only available when you build the car?
Sent from my Pixel 2 XL using Tapatalk
Tylus
South GA
I bought her used 1yr old.
I know service members overseas can order a vehicle with any option configuration they want. I’ve bought a few of those used. They confounded the experts because they had option arrangements that weren’t supposed to exist. I’ve been suspecting this is one of those
I did buy it next to the Navy base I am stationed at.
Tiki
Level time.
cmatt
I need to finish wiring my tow mirrors. So might as well pop the trim off while I have the door panel off
What wiring do you have left to do on the tow mirrors?
Tylus
South GA
Since my ‘Burb didn’t have blinker mirrors, the associated main harness and door harness don’t carry the needed wires. For blinkers and running lights
So I need to run wire taps and run wires to the mirrors
My mirrors also have backup LED spotlights. So I’m going to run a power wire for those as well. F77D72B8-AAF9-4BE9-AA22-0221EEA2BA31.jpeg
humer101
NJ,USA
Got it
cmatt
My mirrors also have backup LED spotlights. So I’m going to run a power wire for those as well. View attachment 225467
Gotcha. If I already mentioned this, sorry for repeating. I can help you with a harness for the tow mirrors if needed.
The turn signal circuits for the mirrors should be present in the door harnesses, but not in the cabin. That’s been my experience with the harness orders I’ve done. Check position 41 on the door side of the connector. If a terminal is present, then they are set up for turn signals.
The suvs don’t have the wiring for the running or cargo lights. My harness will make those features functional.
Tylus
South GA
I’ll look again. But last year when I put the mirrors on there were no pins in the body harness connector. The doors didn’t have the wires either. No turns or running
I built my own harness. Just been too lazy to open it back up. I just moved from CT to GA. Got 2 weeks of vacation. So will finally fix it. Lol
cmatt
Interesting. Please post some pics of the connector ends for the door and body side. You mentioned it probably was a custom build/order. I’m curious to see what the pin out looks like. Interesting to see if GM had their vendor do custom harnesses.
WifesYukon17
Bought it on Saturday (see avatar). Added Husky mud guards, Hikari LED H11 bulbs, and an AEM dryflow filter. I have LED fog bulbs and reverse bulbs waiting for me to install. Will hopefully get to washing, clay bar, and waxing it this weekend. Then I'll be getting the windshield tinted 80% and having a 5% sun bar done as well.
K2 Kaiju
The Depths
How do the mud guards look? Thinking about putting some on...
Sent from my SM-G975U using Tapatalk
K2 Kaiju
The Depths
Added another outlet to "hard wire" the R1 radar - I gotta have that mute button! Also added the cup holders...
Merch619
