2008 Yukon Denali, 135k miles, part 2!!
T
tgui
My guesstimate on where the wideband sensor needs to go was spot on. Tons of room above the driveshaft.
I also found a probable cause to my exhaust leak and pissed off O2 readings. I dropped and didn't install the metal donut gasket to the manifold on the driver's side. Oops.
BG1988
So I tried quality ac Delco rotors and pads. They made it a little over a year before getting warped.
This time im trying raybestos rotors and Bosch ceramic pads. I hope they last longer.
if you don't want them to get warped, don't drive threw water then when they are hot..
T
tgui
Turns out the upstream sensor I installed was from my old gmt800 Yukon. Not compatible. CEL thrown.
95F and %100 humidity today, but fixed. Ick, those welds!
meandmyhoe20
