Air cleaner box gasket???
89Suburban
Bull in the china shop
SE PA
Anybody ever replace this ****** foam gasket? Mine is falling apart and I can't find a replacement gasket part. o_O
89Suburban
89Suburban
SE PA
I'd think Home Depot or Lowes would have foam like that. Looks like the foam you put in window to winterize or cut drafts.
I agree, I just can;t believe there is nothing else out there a little more "respectable" lol.
89Suburban
89Suburban
SE PA
Foam from hd or lowes is probably thicker and better than gm’s stuff....
I got half a can of 3M spray foam adhesive left so I might as well put it to good use and try that foam then. ;)
89Suburban
89Suburban
SE PA
How would you do the spray foam on there?
It's adhesive, I'd mask the box off and spray it down then stick the foam to it. It's better than the peel & stick adhesive that comes with the foam. On 2nd thought, I may spray the inner fender instead ans glue it o that, so it you got to take the box out the gasket stays on the body. Have to take it apart and see what will work out better. :rolleyes:
89Suburban
89Suburban
SE PA
Part # 22844822
About $14-15.
You da man! I wonder if this could be modified somehow using the existing base plate and using some kind of door rubber weatherstripping. :hmm: I will have to investigate...
89Suburban
89Suburban
SE PA
Here is pic of what I am tackling:
meandmyhoe20
